  • Page:
  • 1
  • 2
Oil in carbs? 27 Jul 2023 16:40 #887660
  • Beaner242
  • Beaner242's Avatar Topic Author
  • Thank you received: 16
Just pulled my filters off to clean them. Each carb had a small amount of oil on the lip and in the filter? Never seen this before. It got ran pretty hard last weekend, would that have something to do with it?  Any ideas?  Thanks
1982 KZ1000K LTD Chopper
Oil in carbs? 27 Jul 2023 20:01 #887667
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
Could the filters have been over oiled when they were last installed?
Oil in carbs? 27 Jul 2023 20:54 #887668
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 657
It's probably evaporated fuel if you used ethanol laced fuel. The residue from evaporated ethanol fuel is brown. When fully evaporated its looks like a varnish, this is what clogs carbs if bikes are left for a while without draining the carbs.
There's no engine fluids that get to carbs other than fuel.
Z1000J2 somewhat modified!
Oil in carbs? 28 Jul 2023 04:46 #887676
  • Beaner242
Yes, but not that much. And this was like engine oil.
Thanks warren.  That could be it. Just seemed excessive I got fuel at 3 different stations last weekend though.
Oil in carbs? 28 Jul 2023 04:48 #887677
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1808
Is it fair to assume that you are running pods and the crankcase is venting to atmosphere ?
Oil in carbs? 28 Jul 2023 05:52 #887678
  • Beaner242
Into filter
Oil in carbs? 28 Jul 2023 06:09 #887679
  • Wookie58
  • Wookie58's Avatar
  • Moderator
When you "into filter" is this a separate unit or the air filter (normally if the breather is connected to the air filter oil in the intake is a sign of excessive crankcase pressure)
Oil in carbs? 28 Jul 2023 06:19 #887680
  • Beaner242
Sorry yes I have pods and a separate filter/breather on the case.
Oil in carbs? 28 Jul 2023 06:27 #887681
  • Wookie58
  • Wookie58's Avatar
  • Moderator
There aren't too many options for oil to get into the intake under these circumstances, a leaking valve seal would normally result in the oil being drawn in and burnt. it would be very unusual for oil to find it's way out to the carb intakes ???
Oil in carbs? 28 Jul 2023 06:34 #887682
  • Beaner242
Thanks. That’s what I thought. Like Warren said. Prob a fuel issue. Just never noticed it before
Oil in carbs? 28 Jul 2023 09:08 #887686
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 353
You may be dealing with intake reversion and leaky valve seals.
www.motortrend.com/how-to/ctrp-1008-intake-reversion/
Your exhaust pipe may be sending a strong positive pressure wave back to the cylinder during overlap at certain rpm's.
This is due to pipe length and internal size changes of the primary pipe.
Collector design and placement plays a role as well.
Two stroke tuners have been use this tuning method to their advantage.
You can use it as well but you need to do the math.
The cloud of fuel above the intake trumpets shows reversion in action on the Renault F1 engine.
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Oil in carbs? 29 Jul 2023 06:03 #887698
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2680
Are the valves adjusted properly?  If the intake valves are hanging open, there may be a bit more blow back.
  • Page:
  • 1
  • 2
