KZ305 CV32 secondary main jets different sizes?
- Maverick9D
26 May 2023 08:00 - 26 May 2023 08:32
EDITED: I answered my initial question after posting so i rephrased this into a different question.
Just got my KZ305 running for the first time in decades. Had to break the carb down and go to town cleaning it.
Bike runs and i'm just going through some tuning things like pilot screws, bowl-level and carb sync now. Reading through the manual, i noticed this.
Looks like a different size secondary main air jet for each side? Which part is #8 referring to exactly? Are these the ports at the front of the carb under the choke? Just looking to confirm.
Last edit: 26 May 2023 08:32 by Maverick9D.
- sf4t7
Re: KZ305 CV32 secondary main jets different sizes?
26 May 2023 08:09
They should have the numbers stamped on them. Unfortunately you still have to take them apart to see.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Maverick9D
26 May 2023 08:11 - 26 May 2023 08:14
I edited my initial post as i found more info after posting that cleared up some things. Looks like i misunderstood the difference between "secondary main jet" and "secondary main air jet". Now i just need to ID what the air jet is? Small ports under the choke?
Last edit: 26 May 2023 08:14 by Maverick9D.
26 May 2023 18:55
The air jet is in the mouth of the carburetor.
- Maverick9D
26 May 2023 19:18
Thanks for confirmation.
Did some more tinkering on the carb tonight and I have this thing running very well!
