Sr 650 EFI 12 Jul 2022 05:55 #870231
  • ifranzani
  • ifranzani's Avatar Topic Author
  • Thank you received: 2
I still in the proyect.
i am installing a lambda narrow band at first. The ecu map will do with a wideband lambda. Here is going to be the lambda
Sr 650 EFI 06 Aug 2022 17:44 #871784
  • ifranzani
Before doing a ECU map. Electric start
    IMG_9971.MOV
Sr 650 EFI 06 Aug 2022 17:45 #871786
  • ifranzani
Kick starting.
    IMG_9972.MOV
Sr 650 EFI 06 Aug 2022 17:48 #871787
  • ifranzani
Here gose the lambda sensor. It is a narrow band. Then i going to put a wide band lambda
Last edit: by ifranzani.
Sr 650 EFI 06 Aug 2022 17:50 #871788
  • ifranzani
Here
Sr 650 EFI 08 Aug 2022 14:17 #871886
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
kicking starting a bike with EFI - never seen that before. Are you planning any performance mods?
Sr 650 EFI 08 Aug 2022 14:43 #871889
  • ifranzani
Not performace for the engine, but yes for electrical. Im going to instal a 3 phase stator and a sh775 R/R. And instal a oil radiator too, changing the oil pan for the gpz. I got all for do these mods
Sr 650 EFI 16 Aug 2022 19:15 #872361
  • ifranzani
Update
    FullSizeRender.MOV
Sr 650 EFI 28 Aug 2022 06:20 #872998
  • ifranzani
Ecu map
Sr 650 EFI 05 Jan 2023 14:29 #878573
  • ifranzani
Las adjustments
    IMG_7074.MOV
Sr 650 EFI 05 Jan 2023 14:30 #878574
  • ifranzani
Riding
    IMG_7072.MOV
Sr 650 EFI 05 Jan 2023 14:41 #878575
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1821
Good to see you pushing this project to completion
