  • Page:
  • 1
Kz750 Petcock to carb lines help 02 Jun 2021 19:48 #849509
  • Metraso
  • Metraso's Avatar Topic Author
  • Thank you received: 1
Hello, I recently bought a '79 KZ750 twin. I'm just wondering if someone can show me how to connect the petcock to the carburetors? I've looked everywhere, but I just can't seem to find it.
Thanks, Joshua
The following user(s) said Thank You: tdogm6@yahoo.com
Kz750 Petcock to carb lines help 03 Jun 2021 16:31 #849567
  • tdogm6@yahoo.com
  • tdogm6@yahoo.com's Avatar
I can take pictures of mine and post them when I get off work. It’s a 1980 twin cylinder, but it should be similar, if yours is also a twin.
1980 KZ750G
Kz750 Petcock to carb lines help 04 Jun 2021 07:18 #849600
  • tdogm6@yahoo.com
This email address is being protected from spambots. You need JavaScript enabled to view it. post=849567I can take pictures of mine and post them when I get off work. It’s a 1980 twin cylinder, but it should be similar, if yours is also a twin.
Sorry I took so long.  On my bike, here are fuel two outlets from the petcock, one to the left side of each carburetor. There also two vacuum lines connecting the carbs to each other, which I assume are to help balance them? Hopefully this helps. Maybe a non-newbie can chime in and help is both.
Good luck.
Cheers. ??
1980 KZ750G
The following user(s) said Thank You: Metraso
Last edit: by tdogm6@yahoo.com. Reason: Adding text
Kz750 Petcock to carb lines help 07 Jun 2021 18:08 #849798
  • Metraso
You're a lifesaver man, thank you so much!
Kz750 Petcock to carb lines help 08 Jun 2021 15:35 #849842
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 369
Just to add some more info this link  has pics and explanations about the hose connections and other info.
www.wgcarbs.com/index.php/using-joomla/e...-categories/93-KZ750
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Kz750 Petcock to carb lines help 08 Jun 2021 17:00 #849852
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
So the earlier models use 38mm carbs and the later ones used 34. Was there a change in horsepower ratings?
Kz750 Petcock to carb lines help 09 Jun 2021 07:31 #849874
  • tdogm6@yahoo.com
Do you know if/ where we can find parts for these carburetors
1980 KZ750G
Kz750 Petcock to carb lines help 09 Jun 2021 17:09 #849926
  • gd4now
  • gd4now's Avatar
Tex, I do not know the answer to your question about claimed HP.  IIRC the early machines with the 38s were claimed to make 55 HP not sure about the later models with the 34s.  I may have a manual somewhere that has this info will do some looking and see if I can find it.
Edit OK I did take a look at a manual I have for the 83 year and it appears to cover the K model and it indicates a KW not HP rating of 40.4, which if my math is correct equals 54.17729 HP. So very close to the earlier models with the bigger carbs.
As to parts these are Mikuni carbs, and in general parts for them are easier to find than for the Keihin carbs.  But I have not done any research so do not know for sure, but I tend to look at these two places for Miknui parts - I am sure there are many other locations and members here will most likely provide others.
jetsrus.com
sudco.com
1977 KZ650 B1
This is my Z
Last edit: by gd4now.
  • Page:
  • 1
