  • Page:
  • 1
Petcock 08 Jan 2021 06:15 #841332
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
  • Thank you received: 29
KZ900 I got this fall came with a petcock installed that looked like stock but only had one outlet that went into a "T". Bike seemed to run fine although I drove it less than a mile like that and didn't really get on it. Will this petcock cause the bowls run dry in less than extreme situations? I've come to mostly ride like an old lady on her way to church anymore..
KZ900; Z1
Petcock 08 Jan 2021 07:22 #841338
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 265
Robb,
off the top of my head, I can't think of a bike that has 2 outlets on the fuel petcock. Your setup is pretty standard. Ride it!
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
The following user(s) said Thank You: Robb2018
Petcock 08 Jan 2021 10:57 #841366
  • kevski
  • kevski's Avatar
  • Thank you received: 154
These bikes have come with single and double spigot petcocks according to which years and carbs they come with at time of manufacture, with the single spigot type having a larger bore, if it runs fine keep it as modern replacement taps are hit and miss as to whether they work or not unless you buy Pingel.
Petcock 08 Jan 2021 12:46 #841374
  • Robb2018
  • 76 KZ900 73 Z1 A
kevski wrote: These bikes have come with single and double spigot petcocks according to which years and carbs they come with at time of manufacture, with the single spigot type having a larger bore, if it runs fine keep it as modern replacement taps are hit and miss as to whether they work or not unless you buy Pingel.
God is that true. It's like playing petcock roulette. Unfortunately this petcock seems to have fallen into the black hole more commonly known as my garage, so I'm stuck buying a new one. I had an extra one laying around yesterday that I'd previously bought on Ebay that leaked. I had beefed the seller and he gave me a refund and told me to keep the petcock. For the heck of it, I installed it on another tank I had laying around and filled the tank with water. After tightening it up I found it didn't leak a bit. SO... I put it on the KZ tank, put a couple gallons in and still no leaks. Before going to bed I rechecked it and found it again was slowly dripping gas. I tightened the nut a little and it started leaking more. Tightened it a little more and gas started coming out in a steady stream. So there I was, no bucket handy, gas streaming on to the floor and no way to stop it. Ran got a bucket and funnel, was able to direct most of the gas into the bucket until enough was out of the tank that I could tilt it up and away from the valve and then dumped the rest of the gas into the bucket. Moral of the story, no more Chinese POS petcocks.
KZ900; Z1
Last edit: by Robb2018.
Petcock 08 Jan 2021 16:02 #841384
  • Kaylinator
  • Kaylinator's Avatar
  • Thank you received: 74
slayer61 wrote: Robb,
1977 and 78 KZ1000, part number 51023-1018
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
Petcock 08 Jan 2021 16:36 #841389
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is an alternative to the Pingel. I bought one but haven’t installed it.
Petcock 08 Jan 2021 19:08 #841400
  • Robb2018
  • 76 KZ900 73 Z1 A
That's sweet. Looks a lot like a Pingle.
KZ900; Z1
Petcock 17 Jan 2021 10:21 #841880
  • Kawboy74
  • Kawboy74's Avatar
  • Thank you received: 52
Biggest trick with the Pingel or their copies is to not actuate them dry, they need fuel against the discs and actuating them dry will abrade the surface causing debris to form then a leak.
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
The following user(s) said Thank You: z1kzonly, Mikaw
Petcock 17 Jan 2021 10:35 #841885
  • Mikaw
  • Mikaw's Avatar
Kawboy74 wrote: Biggest trick with the Pingel or their copies is to not actuate them dry, they need fuel against the discs and actuating them dry will abrade the surface causing debris to form then a leak.
Wasn’t aware, thank you.
Petcock 17 Jan 2021 11:23 #841889
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 514
Great products PINGEL! I always use my 'wellworth A2Z" to protect and lubricate Everything! inside, outside, house cellar cars, trucks, motorcycles! But first thing I did when I took these ones apart.. AsI am changing this bike around. Using small LTD tank, a little tight fit. So gives me the reason to Rake the frontend out, which means pulling the 2 studs with the rubber mounts for gas tank back about a 1/2" And I'll solve the clearance issue. I did that with my other bike up on the table lift, same LTD small tank. More work, more projects. I wish I had a neighbor, Kid - Teenager, start him on an apprenticeship program to do my work for me! Pay him with Pizza and Pepsi! Ya', right! kid would say F U old man! $20 bucks an hour. :laugh: :laugh:
Petcock 17 Jan 2021 11:27 #841890
  • Mikaw
  • Mikaw's Avatar
The term is “ok boomer”
  • Page:
  • 1
