KZ1000 A vs. B VM Carbs 02 Jan 2021 12:05 #841051
  • Nessism
  • Nessism's Avatar Topic Author
  • Thank you received: 2677
Okay, I respect the concencess here so I tapped two passages and plugged them, and made a gasket for the top cover. Easily reversible should the next owner desire. The plugs were sealed with 3M gasoline resistant sealer as a hedge. When the new jets arrive these things will be done.
Oh, it's hard to see but the small vacuum passage next to one of the cover holes is plugged with a 4-40 grub screw, and the center hole is plugged because it connects over to other internal passages. Not sure this one was necessary but did it anyway. The larger hole in the bottom of the bowl passes straight through to the bottom of the float bowl. I figured it won't hurt to have this one open since it doesn't go anywhere.
The following user(s) said Thank You: Webbie1
Last edit: by Nessism.
KZ1000 A vs. B VM Carbs 02 Jan 2021 12:17 #841052
  • kevski
  • kevski's Avatar
  • Thank you received: 154
Screw in the centre not needed, now they will operate as all the others with the added bonus of a quick squirt of gas on sharp openings, the circled opening is where i put an m3 grub screw.
Last edit: by kevski.
KZ1000 A vs. B VM Carbs 02 Jan 2021 12:30 #841054
  • Nessism
That passage is plugged. I didn't have an M3 tap so used 4-40.
Waiting on float bowl gaskets and jets, otherwise done.
Not sure why the photo is upside down. Sorry.
KZ1000 A vs. B VM Carbs 16 Jan 2021 12:43 #841818
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Those carbs look very nice that's for sure....
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
KZ1000 A vs. B VM Carbs 22 Dec 2021 06:14 #859456
  • Webbie1
  • Webbie1's Avatar
  • Thank you received: 16
I was having trouble finding the part that you show in the photo.  Then I realized this is only on the carb with the pumper....I'll do that one next.  I just did one of the four so far, and it wasn't the pumper.  I need to still find gaskets.......ordered the o-ring kit that you linked to on Ebay last night.
                                Warner
1979 KZ1000 LTD, 1982 KZ1000 LTD, 1990 Honda CBR1000F
