  • Page:
  • 1
  • 2
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 03 Oct 2020 13:21 #836109
  • kevski
  • kevski's Avatar
  • Thank you received: 154
jonnydirt2 wrote: I know i am sorry i even looked at this post for help now...
As you have the carbs with the screw underneath, don't worry about other types, screws should be around 1 an 1/4 turns out, this is about right for the pilot circuit, to slightly richen screws go out, to weaken turn in slightly. This does not richen and weaken through the whole rev range.
Last edit: by kevski.
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 03 Oct 2020 17:54 #836115
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
kevski wrote: As you have the carbs with the screw underneath, don't worry about other types, screws should be around 1 an 1/4 turns out, this is about right for the pilot circuit, to slightly richen screws go in, to weaken turn out slightly.
Huh???
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 03 Oct 2020 21:23 #836118
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
As you have the carbs with the screw underneath, don't worry about other types, screws should be around 1 an 1/4 turns out, this is about right for the pilot circuit, to slightly richen screws go in, to weaken turn out slightly. This does not richen and weaken through the whole rev range.
"Here's the deal" (famous J.B. quote), it looks to me like this subject was well explained, with diagrams even, and then you go and post this. Are you TRYING to drive the O.P. batsh#t crazy?
Attempt at humor, please accept as such Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 01:05 #836123
  • kevski
  • kevski's Avatar
krazee1 wrote:
K.I.S.S.
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 01:52 #836125
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1470
kevski wrote: This does not richen and weaken through the whole rev range.
To be strictly accurate it does although hardly noticeable as a percentage.
Overall fueling is a stack up of all the circuits put together so any increase or decrease in fuel metered by the pilot screw will be added or subtracted from the total amount received elsewhere.
Last edit: by zed1015.
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 06:06 #836132
  • krazee1
  • krazee1's Avatar
To be strictly accurate, increase or decrease in the fuel and air MIXTURE metered by the pilot screw.
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 06:13 #836133
  • krazee1
  • krazee1's Avatar
K.I.S.S. is a good theory, but your advice is off 180 degrees. The air/fuel mixture screw on the bottom of the carbs is turned OUT to richen, (more fuel and air) and IN (less fuel and air) to lean the idle circuit.
Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 06:18 #836134
  • kevski
  • kevski's Avatar
krazee1 wrote: K.I.S.S. is a good theory, but your advice is off 180 degrees. The air/fuel mixture screw on the bottom of the carbs is turned OUT to richen, (more fuel and air) and IN (less fuel and air) to lean the idle circuit.
Mike
post already edited.
The following user(s) said Thank You: Mikaw, krazee1
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 13:23 #836152
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Dang! and here I thought I FINALLY figured out why my bike wasn't running quite right. Oh well back to the drawing board....
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 04 Oct 2020 19:54 #836182
  • Mikaw
  • Mikaw's Avatar
Maybe this is a good time when the OP hasn't been back in a while. He missed all the Bats@#t crazy stuff.
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 05 Oct 2020 00:01 #836185
  • kevski
  • kevski's Avatar
Mikaw wrote: Maybe this is a good time when the OP hasn't been back in a while. He missed all the Bats@#t crazy stuff.
He probably thought f*#k it I only wanted a quick answer and not the coefficient drag factor of an issosiles triangle while eating a doughnut in the springtime.:laugh:
Mikuni VM26SS fuel mixture or air mixture screw? Which is it? 05 Oct 2020 07:35 #836196
  • Mikaw
  • Mikaw's Avatar
:laugh: :silly:
  • Page:
  • 1
  • 2
