Carbs sending fuel into filter not cylinder 16 Mar 2020 15:55 #821024
  • Bluerider
  • Bluerider's Avatar Topic Author
  • Thank you received: 3
Replaced all gaskets on the top end. Now when it fires up (no issues there) carbs 2 and 3 are not sending the fuel into the cylinder but into the pod filters. Put out two fires thus far. Is this more of a ring issue or a carb issue? 1978 KZ1000LTD. no mods but the pod filters and the frame.
Carbs sending fuel into filter not cylinder 16 Mar 2020 16:20 #821026
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
Check the float levels bet they are to high.
Carbs sending fuel into filter not cylinder 16 Mar 2020 16:25 #821028
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Yup. Should have been checked when the carbs were rejetted.
Carbs sending fuel into filter not cylinder 16 Mar 2020 16:34 #821030
  • Bluerider
Too high or stuck? Will pull them again later. Did rebuild them last year though. Set the carb height based on book with a micrometer.
Carbs sending fuel into filter not cylinder 16 Mar 2020 16:36 #821031
  • TexasKZ
  • TexasKZ's Avatar
Could be sticking.
Carbs sending fuel into filter not cylinder 16 Mar 2020 17:32 #821035
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
Sticking likely. Hope you rejetted for the pods or you will be pulling the carbs again in the near future.
Carbs sending fuel into filter not cylinder 16 Mar 2020 20:26 #821038
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Are the coils connected to the right cylinders?
Carbs sending fuel into filter not cylinder 17 Mar 2020 00:55 #821044
  • calum
  • calum's Avatar
  • Thank you received: 390
To confirm that it's an issue with the floats you could just set the petcock to prime. If it doesn't overflow then the float height should be fine. Are 2 and 3 firing?
Carbs sending fuel into filter not cylinder 17 Mar 2020 03:01 #821045
  • shrap66
  • shrap66's Avatar
  • Thank you received: 14
This just happened to me after doing a carb rebuild. I thought I did everything right. Ultrasonic cleaned. New O-Rings, gaskets, rejet etc.
When I started the bike fuel was flowing from the pods. All 4. The bike was running but something was very wrong.
Could not be a case of stuck valve if all 4.
I had installed the needles upside down. Stupid mistake.
Make sure you drain your oil as it will likely be contaminated with gas.
1979 KZ1000B3 LTD Glacier Green
Carbs sending fuel into filter not cylinder 17 Mar 2020 05:46 #821049
  • jayrodoh
  • jayrodoh's Avatar
  • Thank you received: 27
calum wrote: To confirm that it's an issue with the floats you could just set the petcock to prime. If it doesn't overflow then the float height should be fine.
Good troubleshooting tip, if float levels are correct and needles are seating properly you should be able to leave a petcock on prime (or on for a manual one) without any leakage from carbs.
1982 KZ750-M1 CSR
Carbs sending fuel into filter not cylinder 21 Mar 2020 11:49 #821312
  • baldy110
  • baldy110's Avatar
Float height has nothing to do with float level. Float level is what you need, set the levels using the wet method as described in the manual.
The following user(s) said Thank You: Mikaw, calum
Carbs sending fuel into filter not cylinder 21 Mar 2020 12:01 #821316
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Not a true statement. Don’t trust the measurement method. It’s just to get you close. The only true float level is achieved by the wet method as Baldy110 states. Been there done it. Truly a PITA. COMPLETELY WORTH IT
