Putting fuel tank back on - fuel line, vacuum lines - KZ1000p
- russ_alternate
09 Sep 2018 17:09 #790619
by russ_alternate
Putting fuel tank back on - fuel line, vacuum lines - KZ1000p was created by russ_alternate
Hopefully a couple of simple questions.
It was a long time ago that I took the fuel tank off and got the carbs rebuilt. Of course I didn't take pictures (doh!) so something as simple as putting the tank back on seems challenging. I know how to physically put the tank on but my question is the vacuum / gas lines from the tank to carbs, etc.
On the carbs, I believe the #1 carb and the #4 carb are joined by a vacuum line and tee'd in to a vacuum line going forward on the bike.
The 3rd carb vacuum end is plugged with black plastic which I believe is correct.
So ...
Does the #2 carb vacuum line goes to the petcock?
I assume the gas line on the back of #2 carb goes to the petcock?
Where does the vacuum line by the fuel level indicator go?
Where does the vacuum line at the back of the fuel tank go?
Thanks for any insight.
So ...
- ThatGPzGuy
- Thank you received: 385
10 Sep 2018 05:59 #790641
by ThatGPzGuy
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Replied by ThatGPzGuy on topic Putting fuel tank back on - fuel line, vacuum lines - KZ1000p
You are correct on #1 and #4.
#3 is plugged
#2 goes to the petcock.
That is not a vacuum line coming from the sending unit. It's a drain that is routed on the right side of the bike and ends near the swingarm.
The nipple on the back of the tank is an overflow/drain as well and is routed along the left side in the same way.
#3 is plugged
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: russ_alternate
