- Thank you received: 13
Accelerator diaphragm install ?
- kzdcw
- 77' KZ1000A
04 May 2017 07:28 - 04 May 2017 07:32 #761142
by kzdcw
77' KZ1000A
Accelerator diaphragm install ? was created by kzdcw
Going to install a New accelerator diaphragm in my 28mm pumper carbs. It doesn't appear that the stock one is compromised but since I'm rebuilding these carbs., I thought maybe a new one would be better ?
Anyway the center of the diaphragm has a metal rod that is longer on one side. Which side goes which direction ?
77' KZ1000A
Last edit: 04 May 2017 07:32 by kzdcw.
- Thank you received: 1645
04 May 2017 08:07 - 04 May 2017 13:08 #761151
by martin_csr
Replied by martin_csr on topic Accelerator diaphragm install ?
For the pump diaphragm on the right, the end in the pic faces downward & the pump actuator arm pushes against it. The spring goes on the other side.
Last edit: 04 May 2017 13:08 by martin_csr.
- kzdcw
- 77' KZ1000A
04 May 2017 08:10 #761152
by kzdcw
77' KZ1000A
Replied by kzdcw on topic Accelerator diaphragm install ?
So Martin, The Long end points down ?
77' KZ1000A
04 May 2017 08:12 - 04 May 2017 22:37 #761154
by martin_csr
Yes. When you install it into the accel pump cover, it should be kind of obvious.
vacuum sensor note: on some models the vacuum sensor is disabled at the factory, so the vacuum sensor diaphragm isn't needed. on such models, there usually isn't a vac sensor cover & the triangular diaphragm can't be installed because the center hole isn't drilled.
Last edit: 04 May 2017 22:37 by martin_csr.
- kzdcw
- 77' KZ1000A
04 May 2017 11:02 - 04 May 2017 11:03 #761176
by kzdcw
Last edit: 04 May 2017 11:03 by kzdcw.
