have only tried on one so far, and it is still ok at this point...but you know how that goes - subject to change. will have to try the tighteneing a little trick...dont know why i didnt think of that myself.
no, would never get an imact set in there - way to small...
WiredGeorge has suggested using the p.b. blaster to soak them, and a little bit of heat - after removing any and all rubber pieces of course. heating will be my last resort tho.
wont really be able to work on them much until this weekend. wouldnt be cool going to work smelling like gas and/or carb cleaner!
going to get the full carb kit from Z1. and going to pick up the gallon can size berrymans on friday... hopefully will be able to get everything apart and soaking by saturday evening....looks like another week before i will be getting her fired up.
also need to clean the tank out good....did away with the vacuum petcock - got an adapter plate and standard style petcock but had to file out the hole for the screen a little...which means shavings in there...need to pick up some new fuel line and an inline filter as well...luckily it hasnt been real super nice out (very chilly in the mornings) so i havent been to depressed about not being able to get her out! but the afternoons....wellll....getting itchy!! wanna ride!
