YES, you should take the carbs apart and dip them, but only if you want the bike to run. Order carb kits and a factory repair manual from Jeff Saunders at Z1 Enterprises. You'll also want to drain all that old gasoline and flush the tank and inspect it for rust inside. You'll need to clean out and possibly kit the petcock, too. You'll also want to flush the old brake fluid and replace it with new fluid, and maybe clean out the master cylinder and calipers (again, you might have to kit them). After 17 years the battery will be dead, the tires will be rotten, and the oil and filter will need to be changed (oil will lose it's magic from age, not just mileage).
Oh yeah, we're going to want to see lots of pictures!
