Cam bearing clearance
Re: Cam bearing clearance
05 Oct 2021 08:52 - 05 Oct 2021 08:54
That explains it. It was milled because it was warped? If that's the case homing may be the only option.
Last edit: 05 Oct 2021 08:54 by SWest. Reason: Add clip
- Southpaw
05 Oct 2021 09:35
Both cams self destructed. Just checked the journal diameter there are on the high side of the tolerance in the manual
05 Oct 2021 09:52
I don't understand self destructed. Did it overheat, warp and the cams sized in the bores?
- Southpaw
05 Oct 2021 10:09 - 05 Oct 2021 10:10
I put new bearings in when i originally built the engine, they were too tight i did not check the clearance. Ran it and the bearings and journals got destroyed. Im Starting over trying to avoid that happening again. FBG skimmed the head because its part of there head service. I never thought about the head being warpped causing the clearance issue
Last edit: 05 Oct 2021 10:10 by Southpaw.
05 Oct 2021 11:55
That could be what happened. Honing the bearings or couple won't hurt to get to .001-3.
- Southpaw
06 Oct 2021 06:14
So the honing seems to have done the trick exhaust cam is spinning freely now. Now to check the intake side. Thank you all for your help i appreciate it
