  • Page:
  • 1
  • 2
I'm in need of a Junk Z1 - 6 bolt front rotor 01 Jan 2024 04:15 #893380
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1043
I'll check today.  Happy New Year!!
I'm in need of a Junk Z1 - 6 bolt front rotor 01 Jan 2024 06:59 #893385
  • z1kzonly
  • z1kzonly's Avatar Topic Author
  • Thank you received: 519
Let me look. I bought a front rim complete but I don’t see a date on the rotor. Strange!
  Hi Matt, Glad to touch on the texter with Ya'
Your disc there in picture? Notice the rivet heads? look a little different?  Maybe it was a replacement disc over the years? I'll try and get a better picture of this  8 K coded one. These rivets look like a point dead center of them, with less radius around outer edge?
I'm not in a hurry, I just don't want to ruin an early  '8'  code disc.
I'm in need of a Junk Z1 - 6 bolt front rotor 01 Jan 2024 07:01 #893386
  • z1kzonly
Thanks!  Yes, Happy, Safe, Healthy  New Year to all also!
Marty in Buffalo
I'm in need of a Junk Z1 - 6 bolt front rotor 01 Jan 2024 07:19 #893387
  • z1kzonly
Notice the little dimple? Like a soft serve ice cream cone.
I'm in need of a Junk Z1 - 6 bolt front rotor 01 Jan 2024 09:53 #893390
  • hardrockminer
I checked it this morning.  It's a 9K date code (see right side of photo) and I've had it for several years.  I originally intended to use it on a Z1B I was restoring but I found another one that was correct for the bike and used it instead.  This one was vapour blasted and poorly painted by someone.  I haven't checked the thickness but I can do that if it's important.  Bolt holes are 10 centimeters apart when measured across the diameter.
Last edit: by hardrockminer.
I'm in need of a Junk Z1 - 6 bolt front rotor 01 Jan 2024 19:07 #893417
  • z1kzonly
Hi HRM. Date code or thickness doesn’t matter to me.
it is for a vintage drag bike using an Akront 18” laced to a Z1 hub.
my plan is separate it Blanchard grind it down to 4.5 mm.
then turn 3/8”-1/2”? off outer diameter to match a small Gremica caliper. I have to cut axle down, make a caliper bracket to mate of to a 170’s BETOR 35mm dirt bike frontend!
I have a lot of fabricating to do.
plus? Are you in BC? Canada/US border?
thanks for your time digging this up!
marty in Buffalo
I'm in need of a Junk Z1 - 6 bolt front rotor 02 Jan 2024 04:21 #893422
  • hardrockminer
Yes, I'm in BC but not close to the border.  I'm about 4 hours from Vancouver, on the Trans Canada (#1) Highway.  The nearest city is Kamloops, about a half hour from me.
If you want it, it's yours for $25 plus shipping.  My guess on shipping is $50 to shuffle off to Buffalo.  Matt may want to do a double trade so I'll wait for his reply.
  • Page:
  • 1
  • 2
