  • Page:
  • 1
1983 kz750 L3 08 Aug 2023 07:54 #888045
  • krazinite2003
  • krazinite2003's Avatar Topic Author
  • Thank you received: 0
I am in search of OEM parts for my ride i live in Saskatchewan canada
fuel tank     i don't care about the paint as long as it doesn't have leaks or dents .
both mufflers chrome or black doesn't matter
Engine crash bars
any help would be appreciated thanks
i have two 1983 kz750 L3
1983 kz750 L3 08 Aug 2023 12:56 #888063
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2779
You might want to search the US eBay site for "kz700 mufflers".  There are some there...
1983 kz750 L3 09 Aug 2023 05:38 #888081
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1644
The 1984 KZ700 is very similar to the L3.  Europe got the L4 instead of the 700A US tariff model but they appear to be virtually identical.
Also, the 750L models were sold in the UK and Europe, so that might be a source for parts (L1 thru L4). shipping can be $$$, though.
I think the 82 GPz 750 fuel tank is the same, but don't quote me on that.
Last edit: by martin_csr.
1983 kz750 L3 09 Aug 2023 23:30 #888099
  • Ojisan rider
  • Ojisan rider's Avatar
  • Thank you received: 71
Fuel tank are very hard to come by. It's a unicorn. Here in US, they only had 3 years of availability with that tank (82 - 84). Trust me. I was lucky and score a KZ700 tank long time ago, which went bad and did a restoration (de-rust the tank internal and coated with POR-15). As I had number of pinhole damage, I did look for it, but came up empty. Beware of similar tank. If you indeed have the L3 model, many tanks will look similar, but rear mounting point will be different.  If you have a way to fab up the rear mount, they those maybe an option. In EU, they had GT750 and the tank look very similar, but the rear mount was bit different. Again, maybe you can fab up the mount.
Muffer maybe little easier, but I never cared for the stock Kawasaki unit as you can do a weight training with it. So I prefer 4-1 exhaust. Maybe KZ700 ones?
Engine guard is another one. I did look for and still is, but so far empty. My son will be riding the KZ for little while, so I am looking for engine guard. No, not for me. Getting old but never laid the bike down, yet.
Good luck in your search. What you're looking for is near Unicorn.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
1983 kz750 L3 10 Aug 2023 06:24 #888105
  • martin_csr
By Ojisan rider: ... In EU, they had GT750 and the tank look very similar, but the rear mount was bit different. Again, maybe you can fab up the mount....
From Cmsnl.com the GT750 uses the same rear mount bracket as the 750-L3 & KZ700.  However, it uses a different tank damper that fits over the center frame; the 750P damper fits more rearward.  Not really related, but both the 750L tank damper & 750P tank damper were used on the KZ650-CSR and probably the 750H Ltd. www.cmsnl.com/kawasaki-z750p3-1984-unite...3/partslist/F10.html
GT750 body set listed on EB.UK several years ago.
1983 kz750 L3 10 Aug 2023 06:52 #888108
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 2170
GT550 and GT750 where really popular courier bikes in the UK (shaft drive) so there where a lot about a few years back (they will have had a life though  )
1983 kz750 L3 11 Aug 2023 23:01 #888202
  • Ojisan rider
Thanks martin. I must got mixed up with something else. Can't remember which one, though. While ago, I was trying to fix my tank and thought it may be easier just get another tank.
Sorry krazinite2003, Didn't mean to hi-jack your thread.
Last edit: by Ojisan rider.
1983 kz750 L3 12 Aug 2023 06:00 #888207
  • martin_csr
I don't know if the GT750 tank will work on the L3, all I know is that they use the same rear mounting bracket.  The different tank damper is a consideration >> maybe the tank tunnels are different? I've never compared the underside of the two tanks.
1983 kz750 L3 23 Oct 2023 18:41 #890868
  • darlington
  • darlington's Avatar
  • S. Darlington
  • Thank you received: 3
Did you get everything you needed ? Steve This email address is being protected from spambots. You need JavaScript enabled to view it.
Keeping the good times rolling since 1982. Helping people with parts ,technical support and service of the 70's 80's Kawasakis. Building road bike bikes for individuals involved in Vintage Road Racing in the eastern Ontario region.
  • Page:
  • 1
