  • Page:
  • 1
KZ1000 attaching screws for the back of indicator tree 07 Aug 2023 11:41 #888029
  • Bogie1
  • Bogie1's Avatar Topic Author
  • Thank you received: 8
I am missing one screw and one has a bad head,
does any one have any they would part with.? I want two.
these screws hold the back cover on the indicator lamp tree. of my 1978 kz1000
there approx 3mm wide and overall length 10.mm
Thanks Mike
Mike Bogos
1978 Kawasaki 1000 LTD
1977 Kawasaki KZ1000 Project
1982 Suzuki 1100 L
1971 Rupp Roadster
1965 Olds 442 Conv
1970 Olds 442 Conv
Last edit: by Bogie1.
KZ1000 attaching screws for the back of indicator tree 07 Aug 2023 15:06 #888031
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2091
Ace Hardware probably has them in stock.
Assuming yours is an LTD, they are still available from Kawasaki, if you don’t mind paying extra. Looks like they are 3 X 8.
www.partzilla.com/product/kawasaki/220B0...d09d54975a2e82217c04
The following user(s) said Thank You: Bogie1
Last edit: by TexasKZ.
KZ1000 attaching screws for the back of indicator tree 07 Aug 2023 15:12 #888032
  • TexasKZ
  • TexasKZ's Avatar
P.S. Be sure to use JIS screwdrivers rather than Phillips to prevent any more buggered screw heads.
KZ1000 attaching screws for the back of indicator tree 07 Aug 2023 16:26 #888035
  • Bogie1
will do.
try to straighten out 45 years of the wrong tools
Mike Bogos
1982 Suzuki 1100 L
1971 Rupp Roadster
1965 Olds 442 Conv
1970 Olds 442 Conv
KZ1000 attaching screws for the back of indicator tree 07 Aug 2023 16:27 #888036
  • Bogie1
any idea what the thread pitch is?
Mike Bogos
1982 Suzuki 1100 L
1971 Rupp Roadster
1965 Olds 442 Conv
1970 Olds 442 Conv
KZ1000 attaching screws for the back of indicator tree 07 Aug 2023 20:07 #888040
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 264
M3 screw threads coarse thread is .50mm pitch.  Another good source is boltdepot.com .  They sell zinc plated or stainless steel hardware at good prices.  If you use the stainless screws don't forget to use anti seize, especially if threading into aluminum !
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: howardhb, Wookie58, Bogie1
KZ1000 attaching screws for the back of indicator tree 10 Aug 2023 12:16 #888122
  • jwfels
  • jwfels's Avatar
  • Thank you received: 32
Also, Belmetric in Mass., that looks like a sems screw,(built in washer), they sell them, got them for carbs there
Z1A AND 81 650
  • Page:
  • 1
