  • Page:
  • 1
Kawasaki Z1100R camshaft wanted 23 Feb 2023 03:08 #880665
  • davecullen
  • davecullen's Avatar Topic Author
  • Thank you received: 0
Hi Guys, casting my net wide I know but my Z1100R is currently getting an engine rebuild and amongst other problems, it appears the exhaust camshaft is "blued" but just within service limits, so ive been advised to try and find a decent used one to be on safe side as NOS parts are no longer available.
Having looked at the CMSNL website part diagram, it appears the part no for inlet and exhaust are the same, 12044-1057 and they are common to the ELR and the 83-85 Z1100A1-A3, aka the Gpz 1100 unitrak.
Does anyone have one in good condition they would be willing to part with, any help or advice appreciated.
Thanks
Z900A4 Z1000A1 Z1100R ZRX1100C4
DAVECULLEN
Kawasaki Z1100R camshaft wanted 23 Feb 2023 07:12 #880673
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1922
KZ/GPZ1100 cams are different in duration and lift ,so the engine power/torque band can perfom from mild to hot.
Can you please post some pics of your "blued" exhaust camshaft.
www.kzrider.com/forum/2-engine/590239-st...l-cam-options#598747
Here are some GPZ1100 B cams for sale: www.ebay-kleinanzeigen.de/s-anzeige/kawa.../2110995153-306-5489
Last edit: by Scirocco.
Kawasaki Z1100R camshaft wanted 23 Feb 2023 07:44 #880674
  • davecullen
Hi
Thanks for reply, I'm just going on basis of CSMNL info that the camshaft 12044-1057 is the correct one for my ELR  and that Gpz B ones aren't correct.
Bike is with the engine builder at the minute, he informs me the camshaft is still just within service limits but it would be worth trying to find another.
Will just need to watch ebay carefully.
DAVECULLEN
Kawasaki Z1100R camshaft wanted 23 Feb 2023 16:07 #880693
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
B1 cams are 280*, same as a J model
B2 cams are 288*
UniTrack cams are 300*
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Kawasaki Z1100R camshaft wanted 23 Feb 2023 16:53 #880698
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
B2 cams are 288*
Lift? Stock Kz900 cams are around 345 lift.
Kawasaki Z1100R camshaft wanted 23 Feb 2023 23:32 #880705
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1899
Mikaw I believe these are duration specs in degrees, that being the case 300 degrees is pretty "cam-y" for a stock motor (280-290 is common as a "fast road" spec)
The following user(s) said Thank You: Nessism, Mikaw
Last edit: by Wookie58.
  • Page:
  • 1
