  • Page:
  • 1
  • 2
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 18 Mar 2022 07:07 #863965
  • Deuce
  • Deuce's Avatar Topic Author
  • Thank you received: 4
I'm searching for a gauge cluster for my bike.  Extremely outrageous prices on eBay.  I bought a gauge cluster for my 1982 Honda 900F for about $65 on eBay a few years ago, so paying $400 for a set for the 1000 would be a bit shocking, for me at least.
Thanks in advance!
www.flickr.com/gp/162005819@N03/J055kUZ1a8
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 18 Mar 2022 07:23 #863967
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Are you trying to keep it stock or close to stock? Asking because you could use quite a few different Kawasaki meters, but with non-stock you'd have to fab a meter bracket & do some rewiring.
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 18 Mar 2022 07:40 #863971
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1874
They make these aftermarket at a reasonable price. I have no personal experience with them….
Speedometer……… 323880318298
Tachometer……… 303248923921
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 18 Mar 2022 07:47 #863972
  • martin_csr
Beware cheap chinese meters. I did not search those item numbers.
Last edit: by martin_csr.
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 19 Mar 2022 08:47 #864036
  • Deuce
As close to stock as possible.  I bought a KZ 400 gauge cluster and while it looks close, I'm not sure how well it will work.  Redline is the same, but it doesn't have the 160 speedo.  If I can get it apart okay, they do have a new faceplate for it.  I tend to buy things before I need them, and then I find out I should have done more research on it.  I've seen the "replacement" gauges from China, but I am trying to keep my Chinese purchases to a minimum, if at all.  Unfortunately, sometimes you have to bite the bullet and get it from there.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 20 Mar 2022 09:04 #864081
  • martin_csr
Z1Resto refurbishes 70s style meters. I guess he's still around. There's also a guy in the UK.
From the cross-reference at Partzilla the 70s KZ650s use the same meter bracket, so I would assume those meters could be used. But you may encounter the same problem about pricing. Good sets will be expensive & cheaper ones won't be in great condition.
ps: made in china repros are known to fail.
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 20 Mar 2022 09:35 #864084
  • usa forever
  • usa forever's Avatar
  • Thank you received: 5
These are earlier then 1979  , 65.00 plus shipping.  I may have black covers but have to look.
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 23 Mar 2022 11:13 #864229
  • Mr. E
  • Mr. E's Avatar
  • Thank you received: 14
I would be interested in these. Shot you a DM
1981 KZ750 Chopper, 1975 KZ400 , 1984 GPZ750 track build , Res 1977 kz1000a ,1977 kz1000a ...ect.
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 25 Mar 2022 05:57 #864281
  • Deuce
Thanks!  I pm'd you as well.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 25 Mar 2022 09:52 #864294
  • Nerdy
  • Nerdy's Avatar
  • Away
  • Thank you received: 386
Well, yeah - there's no need for a 160mph speedo on a KZ400.
To be brutally honest even 120mph is overkill. The 85mph speedo is probably about right.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 25 Mar 2022 10:31 #864295
  • martin_csr
I'm pretty sure he bought the Honda meter assy for his 1000. :)
Needed: 1979 KZ1000 gauge cluster (or whatever will work) 25 Mar 2022 16:28 #864303
  • Nerdy
  • Nerdy's Avatar
  • Away
Yep - I got a little sidetracked.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Page:
  • 1
  • 2
