  • Page:
  • 1
Kz1000A timing advance 07 Dec 2021 17:38 #858769
  • Samminorwich
  • Samminorwich's Avatar Topic Author
  • Thank you received: 1
Hi I live in the UK have no timing or points or anthing to get ignition totally bare crank end has anyone got some good part so I can progress
re
Kz1000A timing advance 07 Dec 2021 22:42 #858774
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1907
Z-Fever in Germany sells a lot of good used parts for reasonable prices.
Customers from outside EU and foreign business customers with International VAT Number not have to pay the German VAT (-19%).
z-fever.de/shop/en/?cat=c638_ZUeNDANLAGE-ZUeNDANLAGE-638.html
Breaker assy = 35 Euro
Advancer assy = 45 Euro
Bolt and washer advancer = 14,50 Euro
The following user(s) said Thank You: Mikaw, Bob Maximum, Samminorwich
Last edit: by Scirocco.
Kz1000A timing advance 08 Dec 2021 12:32 #858826
  • Bob Maximum
  • Bob Maximum's Avatar
  • Thank you received: 4
I'm also from the U.K. and don't remember coming across Z-fever before. Thanks for posting the link.
1972 Kawasaki F8a bison with 350cc top end.
1975 Kawasaki F9c bighorn 350cc
1978 Kawasaki KZ1000 LTD
1984 Yamaha XT600
2006 Yamaha FJR 1300
Kz1000A timing advance 08 Dec 2021 13:07 #858834
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
And, in addition to what Scirocco posted, you could forego the points plate and install a Dyna S which will have it's own timing plate.  You will still need the advancer that Scirocco linked to, along with the bolt and hex-key.  In case you are not aware, a Dyna S is a pretty common, reliable, and affordable ignition used on old Kz's.  You can use the original coils if you have them or get new coils.  The new coils must be 3-ohms or higher in primary resistance.  (The original points coils were 4 ohms.)
  • Page:
  • 1
