  • Page:
  • 1
Tach drive gear for '81 KZ750e 28 Sep 2021 11:33 #855871
  • Skidmark
  • Skidmark's Avatar Topic Author
  • Thank you received: 260
I am looking for a good used tachometer drive gear.  Mine has some wear grooves where the seal rides.  Looking for a replacement with a smooth, clean shaft without wear grooves.  Thanks!
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Tach drive gear for '81 KZ750e 28 Sep 2021 12:14 #855874
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 373
I think the part# is 13223-011 and was used on many different models and years.  This should allow for a larger pool of used parts.
Partzilla indicates it was used on many bikes see this link
www.partzilla.com/product/kawasaki/13223...70ea57e8b0bc8131a535
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Tach drive gear for '81 KZ750e 28 Sep 2021 17:16 #855888
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1905
Your tach drive is looking good. The shaft only need a light polish and a new seal and nothing more.
A sample of a clutch push rod with real wear grooves i have fabricate new to the GPZ1100 engine i sold to  kzstreetfighter71
The following user(s) said Thank You: Nessism, Skidmark
Last edit: by Scirocco.
Tach drive gear for '81 KZ750e 29 Sep 2021 08:01 #855901
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
I agree with Scirocco on this item.  It doesn't look bad at all really.  If you have a micrometer you could measure the wear difference, but just from the picture before I went looking for a new one I would put it in a drill/mill chuck and spin it while using some very fine sand paper, or crocus cloth to polish the worn looking area.  Hit it with some metal polish at the end and see how it turns out.  Install a new seal after that and you may be GTG.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Tach drive gear for '81 KZ750e 29 Sep 2021 09:27 #855908
  • Skidmark
The worn area is .001" smaller in diameter, and I can feel the edge with my fingernail.  Looks worse than it really is.  New o-ring and seal is already on the way.  I will try the polishing and see.  I just don't want an oil dribble.
Retired gearhead
'81 KZ-750 E2
Tach drive gear for '81 KZ750e 29 Sep 2021 12:02 #855912
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
A new oil seal has more flexibility and tention and is able to handle a "worn out" .001 smaller in diameter shaft.
Tach drive gear for '81 KZ750e 29 Sep 2021 16:03 #855923
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2681
My tach drive gear looks worse than yours and it's oil tight.  I was looking for a better one for a good price but until this thread, I forgot about it.
Tach drive gear for '81 KZ750e 29 Sep 2021 16:36 #855926
  • Skidmark
I gave it some sand paper love.  Still a groove present, but I'll run it as is and monitor the new seals.  Thanks, guys...
Retired gearhead
'81 KZ-750 E2
The following user(s) said Thank You: Rick H.
  • Page:
  • 1
