  • Page:
  • 1
1980 ltd 1000 crankshaft 13 Jul 2021 12:07 #851666
  • texasfisherdude
  • texasfisherdude's Avatar Topic Author
  • 2 old 2 fat dont care
  • Thank you received: 2
Due to water damage I'm in need of a crankshaft. (2 bad bearings) 1979 to 1980 1000 any help would be appreciated
Life's to short to drink cheap beer
1980 LTD 1000
1980 ltd 1000 crankshaft 17 Jul 2021 14:33 #851925
  • bluezbike
  • bluezbike's Avatar
  • Thank you received: 104
I have one good one off a 78...I believe they all fit the basic KZ 1000 models until you get to the J models.  $150 plus shipping from 98110  Let me know.
79 KZ 1000 LTD
1980 ltd 1000 crankshaft 17 Jul 2021 15:22 #851928
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
The 79 and 80 are the MK2 engine, and have a different number of teeth on the crankshaft cam chain sprocket.  I believe you could use a 73-78 crank in a 79/80, but you'd need to change the camshaft sprockets to the 73-78 sprockets.
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: bluezbike
Last edit: by DOHC.
1980 ltd 1000 crankshaft 17 Jul 2021 21:38 #851953
  • bluezbike
Very true on the change in 79, totally spaced on that....my bad, thank you DOHC
79 KZ 1000 LTD
Last edit: by bluezbike.
1980 ltd 1000 crankshaft 18 Jul 2021 11:59 #851972
  • texasfisherdude
is the chain the same?
1980 LTD 1000
1980 ltd 1000 crankshaft 18 Jul 2021 12:08 #851973
  • Dragbike_Mike
  • Dragbike_Mike's Avatar
  • Thank you received: 105
The cam chains are not the same, unfortunately.  The chain used on pre-MkII motors (Z1, KZ900, early KZ1000) having the 15t crank center pin use 122 links.  The MkII chain is 124 links.  Hope this helps.
Mike
Presently - 1980 KZ1000B4 LTD w/mild ported head, Megacycle cams, 1015cc Wiseco, Falicon Supercrank, R&D undercut trans
The following user(s) said Thank You: texasfisherdude, bluezbike
1980 ltd 1000 crankshaft 18 Jul 2021 14:24 #851974
  • texasfisherdude
I read somewhere that the rotor for the stator-generator is different due to the crank being larger and the taper is different is this true?
1980 LTD 1000
1980 ltd 1000 crankshaft 18 Jul 2021 20:39 #851990
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 122
The 79 and 80 are the MK2 engine, and have a different number of teeth on the crankshaft cam chain sprocket.  I believe you could use a 73-78 crank in a 79/80, but you'd need to change the camshaft sprockets to the 73-78 sprockets.not all 79/80 KZ1000 were MKII LTD Models used the 122L cam chain same as older Models but 79/80 used different taper on end for stator than 77-78 KZ1000 I may have 79/80 LTD 1000 crank
1984 750 Turbo
1980 ltd 1000 crankshaft 19 Jul 2021 10:38 #852031
  • bluezbike
This may prove to be a bigger pain than I thought. The dynamo charging systems are different, you would have to get an earlier side cover and complete rotor assembly. 77-78 uses a magnetic rotor dealio fixed to the crank and the armature is fixed to the side cover....while on the later 79-80 Mk2 motors the dynamo charging system is reversed.  I would totally understand if you didn't want the crank, my apologies
79 KZ 1000 LTD
1980 ltd 1000 crankshaft 19 Jul 2021 13:50 #852042
  • texasfisherdude
starting to look like a bit of a pita for sure
1980 LTD 1000
1980 ltd 1000 crankshaft 02 Aug 2021 13:06 #853043
  • texasfisherdude
found one thanks guys
1980 LTD 1000
  • Page:
  • 1
