  • Page:
  • 1
  • 2
78 kx650 stator cover 22 Apr 2021 19:41 #847256
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
Unfortunately I don't think I can have this thread saved. Anybody has spare?
Last edit: by katit.
78 kx650 stator cover 22 Apr 2021 20:12 #847258
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
Why not install a helicoil?  Auto parts stores sell kits with the appropriate tap.  Just make sure to use the correct drill bit first.
78 kx650 stator cover 22 Apr 2021 20:18 #847260
  • katit
Its drilled off center, no way I can drill it correctly for helicoil. I believe it’s m5 in there and pretty tight clearance. If inexpensive cover available Id rather replace. I have one from 79 but it looks little different on logo, also a possibility
78 kx650 stator cover 23 Apr 2021 04:58 #847267
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
Have you checked ebay?
78 kx650 stator cover 23 Apr 2021 09:21 #847294
  • katit
Sure I did, I was checking community first
78 kx650 stator cover 23 Apr 2021 11:44 #847298
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
There is a lot of Aluminum left to do a Timesert repair!!!
78 kx650 stator cover 23 Apr 2021 12:08 #847299
  • katit
How? It's not about just inserting it. It's about making it in correct location. Hole drilled off-center. How do I drill it to restore correct position?
And.. Cost of timesert kit for M5/M4 (not sure which one need to check) will probably be close to another cover.
78 kx650 stator cover 23 Apr 2021 12:28 #847302
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Use the stator body screw holes as a bore guide to center pilot 6 mm drill bit, easy naa....
The following user(s) said Thank You: katit
Last edit: by Scirocco.
78 kx650 stator cover 23 Apr 2021 12:36 #847303
  • katit
Duh.. Ok. I guess I am trying to overthink stuff.
Anyhow.. M5 (this is what it is) timesert kit is like $80.
I will see maybe use my M6 timesert kit if there is enough meat and then just enlarge hole in stator body a little.. Hope it works.
78 kx650 stator cover 23 Apr 2021 12:45 #847304
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
It´s a M6 bolt thread you have to repair....
78 kx650 stator cover 23 Apr 2021 12:51 #847306
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
I only found 5 or 6 like yours with the cross-hatch pattern on EB. one of them is nos & over-priced.  3 or 4 are in the $55T range.
There's one from a 79 model that's $28T but it doesn't have the cross-hatch pattern.  None of them looked that great.
search terms I used:  KZ650 generator cover. also searched KZ650 with: alternator cover. stator cover. dynamo cover. engine cover.
78 kx650 stator cover 23 Apr 2021 12:57 #847307
  • katit
Nope. This is M5 allen bolts ther
BOLT-SOCKET,5X30 (Ref # 28) 120P0530
  • Page:
  • 1
  • 2
