  • Page:
  • 1
1981/1984 valve shims 19 Apr 2021 16:55 #847060
  • Claude.
  • Claude.'s Avatar Topic Author
  • Thank you received: 34
I already have a few 1981-1984 KZ1000/1100 in my garage and will eventually need some valve shims.
I assume they all use 29mm diam. shims aren't they?
What thickness range is usually needed?
Does someone here a a kit or starter kit they don't use anymore and would like to sell?
Is so, please let me now.
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
1982 KZ1000J2 (another one!)
2017 Yamaha FZ07
1981/1984 valve shims 19 Apr 2021 17:26 #847062
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2706
The valves sink in the seats with mileage so thinner shims are needed when adjusting the valves, never thicker.  So whatever thickness your current shims are you need thinner.  Any shims you buy thicker than your current shims will never get used.
Reasoning for mentioning this is because buying a "shim kit" often results in purchasing a lot of sizes you will never use.  You would be well advised to take an inventory of your current shims and then purchasing shims thinner by some reasonable margin.  For example: if your engine has a bunch of 2.75 shims buy some from between 2.70 to 2.50.  There is no use in getting any 2.30's or 2.80's.
The following user(s) said Thank You: Claude.
1981/1984 valve shims 19 Apr 2021 17:33 #847063
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1041
I know my wife's 1981 KZ550 uses the small shims under the bucket.  You may want to check to see if your bike uses shims over the bucket.  If so they will be the large ones.  Otherwise they will be the small ones under the bucket....a more complicated change out.
  • Page:
  • 1
