  • Page:
  • 1
KZ750 e 10 Apr 2021 20:41 #846488
  • Akiwi
  • Akiwi's Avatar Topic Author
  • Thank you received: 0
 Want to buy a good set of carbs for a Kz750e
Also centre console between gauges that has indicator, high beam oil light etc...displayed
KZ750 e 10 Apr 2021 20:58 #846489
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2706
Checked ebay and didn't see any.  The Spectre carbs are similar but likewise, none available.
Do you have a set of carbs now?  If so, what's wrong with them?
KZ750 e 10 Apr 2021 21:02 #846490
  • Akiwi
Yes I do, they are pretty gummed up and nasty.
I also had a set from a GPX750 I’ve decided not to use so as to keep it original.
KZ750 e 10 Apr 2021 21:38 #846491
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2088
Gummed up carbs can be cleaned.
KZ750 e 10 Apr 2021 22:25 #846492
  • Akiwi
Yeah, looks like that’s the way to go. I was hoping to get a better base set to start with. Should I get them ultrasonically cleaned?
KZ750 e 11 Apr 2021 04:50 #846499
  • Nessism
  • Nessism's Avatar
Carb dip works better than ultrasonic for cleaning.  The carbs need to be taken all the way apart in order to clean them properly.
I've done a fair number of sets of those carbs.  If you search around in the archives you will find posts in several threads detailing what O-ring sizes you need.  PM me if you have any questions and I'll try to help.
Last edit: by Nessism.
KZ750 e 13 Apr 2021 08:26 #846632
  • usa forever
  • usa forever's Avatar
  • Thank you received: 5
Nice set like New , not rebuilt  . 1980 kz750
also ,1,000 miles on carbs . Stock air box.
.  Head was to be worked for turbo but never got to it. Very nice shape
my contact is this cell or This email address is being protected from spambots. You need JavaScript enabled to view it.
 thanks, Jim
Last edit: by usa forever.
KZ750 e 16 Apr 2021 17:24 #846906
  • Akiwi
Have emailed
  • Page:
  • 1
