  • Page:
  • 1
  • 2
Help ID 4/2 exhause, please. 22 Mar 2024 01:59 #896733
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1821
MODS - just realized that slmjim posted the wrong OD of the retaining collars in the OP as 50mm. Oops...
They are 40mm.
Please correct or, enable edit & we will do so early AM tomorrow.
Thx.
Good Ridin'
slmjim & Z1BEBE
Done
The following user(s) said Thank You: slmjim+Z1BEBE
Help ID 4/2 exhause, please. 24 Mar 2024 05:16 #896822
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
  • Thank you received: 620
I've been meaning to pull the ancient 4-into-1 off the '81 GPz550. Let me see if that can happen this weekend; if so, I can get some measurements.
Thanks Scott.  Perhaps there's a 4-2 system in your GPZ-550's future at a price you can't resist?
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The following user(s) said Thank You: Nerdy
Help ID 4/2 exhause, please. 24 Mar 2024 19:29 #896857
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 381
You read my mind
Regrettably I didn't get into the shop this weekend, but had an idea. Tucked away in the basement are two new-in-box MAC 4-into-1s for the GPz. I can get one of them open and take some detailed measurements.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Help ID 4/2 exhause, please. 02 Apr 2024 14:15 #897180
  • Nerdy
  • Nerdy's Avatar
Okay, I finally made it down to the shop Here are the measurements from the newer of the two MAC pipes:
- the flange diameter at the head (the part that sits on the exhaust gasket) is 38mm
- the outside-to-outside of the 3-4 headers (close to the head) is 119mm
- the inside-to-inside distance between 3-4 is 41mm
- the center-to-center of 3-4 at the flange is 83mm
I did these using a really basic set of Harbor Freight calipers but they should be pretty close. The center-to-center might be a little suspect since I eyeballed the caliper points.
EDIT: let's put slmjim's measurements in here, too
Center-to-center of 1/2 and 3/4 headpipes is ~88mm -  ~3 1/4in.
OD of headpipe collars is. 40mm
OD of collector(s) out is 48mm.
OD of connector pipes is 48mm.
The verdict seems to be that the exhaust in question will not fit a 1981 GPz550. Dang it. :(
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
Last edit: by Nerdy.
  • Page:
  • 1
  • 2
