Best penetrant part 53.6
  • TexasKZ
  • TexasKZ's Avatar Topic Author
19 Dec 2018 07:56
#795414
  • old_kaw
  • old_kaw's Avatar
Re: Best penetrant part 53.6
19 Dec 2018 08:12
#795416
I don't know how they all compare in terms if effectiveness, but the PB Blaster is some NASTY smelling stuff. AND in turn when you use it, YOU become some nasty smelling stuff. Use at your own risk. :-)
PS: I have not watched the video yet.
1981 Kawasaki Kz1000K1
  • martin_csr
  • martin_csr's Avatar
19 Dec 2018 08:28 - 19 Dec 2018 08:31
#795418
For the homemade concoction what would be a good ATF to use? I don't think they're all the same.
I've had good luck using Liquid wrench penetrating spray lubricant which has worked very good in various applications, including some EGR valve bolts which are purported to be difficult to remove. I did try acetone + Ford ATF on some exhaust manifold heat shield bolts but can't really say if it was any better or worse than LW.
Last edit: 19 Dec 2018 08:31 by martin_csr.
  • old_kaw
  • old_kaw's Avatar
19 Dec 2018 08:43 - 19 Dec 2018 08:43
#795419
Replying to Martin's DIY penetrant, I have been told WD is just kerosene, or diesel fuel.
As far as brand name penetrants, I usually use WD, but prefer Seafoam brand "Deep Creep" (not in video) but it is ~$11.00 for a spray can, where as WD is ~6 bucks for a can.
I don't care much for the WD squirter nozzle either since after it gets tossed around in my tool bucket a few thousand times, it becomes pretty much usable on a half full can. (service tech work).
Last edit: 19 Dec 2018 08:43 by old_kaw.
  • martin_csr
19 Dec 2018 09:29
#795422
When you say wd, do you mean regular wd-40 or one of their new wd40 penetrating oils? Because regular wd40 isn't really a penetrant. : )
  • old_kaw
  • old_kaw's Avatar
19 Dec 2018 10:44
#795429
martin_csr wrote: When you say wd, do you mean regular wd-40 or one of their new wd40 penetrating oils? Because regular wd40 isn't really a penetrant. : ) ...
Yes Martin. WD-40
This stuff. :-)
  • 2strokerider
  • 2strokerider's Avatar
19 Dec 2018 14:56 - 19 Dec 2018 14:57
#795435
Last edit: 19 Dec 2018 14:57 by 2strokerider.
  • Nessism
  • Nessism's Avatar
19 Dec 2018 16:56
#795439
WD-40 is a petrochemical cleaner/carrier along with light oil. The MSDS can be found online.
19 Dec 2018 17:13
#795441
Based on a recommendation from a very experienced engineer friend of mine I use Kano Kroil. Over the past couple decades I've used it on some extremely stubborn bolts & screws and it has always worked extremely well. I let them soak for 2 or 3 days and Kroil breaks the bond. Here's the flavor I use. Ed
www.kanolabs.com/google/
The following user(s) said Thank You: BCScott
  • KZB2 650
  • KZB2 650's Avatar
20 Dec 2018 05:07
#795460
Was glad to see Liq wrench do so well.......... always what my dad used and me as well.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
20 Dec 2018 06:19
#795461
Oil thread 2.0
Where's that popcorn emoji when you need one?
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • TexasKZ
20 Dec 2018 06:50
#795462
slmjim+Z1BEBE wrote: Oil thread 2.0
Good Ridin'
slmjim & Z1BEBE
:whistle:
