Carb sync tool? 28 Feb 2016 07:03 #712825
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
Old Man Rock wrote: Nothing better than this.... ;)
Never thought much about ever changing from the old carb stick (first tool I bought (81) along side with the manual and tickle charger) but after it fell apart and leaked out the mercury I went with one of these and am glad I did.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Carb sync tool? 28 Feb 2016 07:36 #712839
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Mine work fine but I protect it. One of those may be in my future though. We'll see.
Carb sync tool? 28 Feb 2016 08:30 #712848
  • Wyliecoyote
  • Wyliecoyote's Avatar Topic Author
  • Thank you received: 0
Thx for the input I'll start checking eBay ....for the car tune unit!
Carb sync tool? 20 Mar 2016 06:21 #716301
  • KZRog
  • KZRog's Avatar
  • Thank you received: 5
No eBay APP ID and/or Cert ID defined in Kunena configurationI got this one and it couldnt be simpler.
Two disadvantages of it are you cant take an actual vacuum reading, and you can only do 2 carbs at a time. But it is stupid simple to use and VERY cheap. I took a short video when I did mine, just showing it working. The vid was actually too short so I had to slow it down so it would last more than 3 seconds :)
1977 KZ650 B1
1982 KZ1100 A2
2006 TW200
2009 TW200
2011 Sportster 48
Last edit: by KZRog.
Carb sync tool? 20 Mar 2016 11:11 #716344
  • GKBO
  • GKBO's Avatar
  • Saving old"dead" bikes
  • Thank you received: 10
I got my Carbtune direct from Morgan www.carbtune.com/ Nobody short of getting a used one will give you a better price because they all get them at the factory pricing.Got it in 1 week from Northern Ireland to Canada's far west coast.Getting the case is a good investment as it keep it all in one place.Never use my old mercury Motion Pro stix again.
Carb sync tool? 20 Mar 2016 14:18 #716359
  • Little B
  • Little B's Avatar
  • Thank you received: 3
Will I need to do this after I get my carbs back from Wired George?
1981 KZ750-H2 LTD
Carb sync tool? 20 Mar 2016 15:30 #716363
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2678
Little B wrote: Will I need to do this after I get my carbs back from Wired George?
After you get them back from George you may have to rebuild them totally. I've seen some of his work before and buyer beware.
Carb sync tool? 20 Mar 2016 15:58 #716371
  • KZB2 650
  • KZB2 650's Avatar
Even if he's got em bench sync'd close buy the time you get em on they will probably be made closer by using the gauges..... and besides a little down the road you will need to re do em again anyway........ and I got my set from the factory quick and just under a 100 too but I now see Ebay is very close to this now.
1978 KZ650 b-2
Carb sync tool? 20 Mar 2016 17:09 #716393
  • Little B
  • Little B's Avatar
KZB2 650 wrote: Even if he's got em bench sync'd close buy the time you get em on they will probably be made closer by using the gauges..... and besides a little down the road you will need to re do em again anyway........
Ok, thanks.
Everything I've heard about WG has been positive so I'm guessing that Nessism was joking.
1981 KZ750-H2 LTD
Carb sync tool? 20 Mar 2016 19:59 #716428
  • SWest
  • SWest's Avatar
  • 10 22 2014
I've heard both.
Carb sync tool? 20 Mar 2016 21:16 #716453
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
George (WG) used to be a member here until several other members got really bad service from him. If the really old discussions are still accessible, you should be able to find several long, angry discussion threads.
Carb sync tool? 20 Mar 2016 21:28 #716458
  • Little B
  • Little B's Avatar
Damn, that is unfortunate. I'll let everyone know how mine come back.
1981 KZ750-H2 LTD
