Eastwood Welder TIG 200 review
- DoctoRot
03 Mar 2015 18:34
I recently picked up a Eastwood TIG 200. It was a bargain at $750 with a 3 year warranty and 60 day return policy. It came with pretty much everything you need to get started except for a hood, argon bottle, and filler rod. I set it up at my buddies welding shop and with a little instruction from him was able to make some pretty fair beads for my first time TIG welding. my only other experience is a little bit of gas welding. The cool part is all of these passes were made using a standard 110volt outlet, even for the aluminum. I could weld in my bedroom if I wanted :lol: I'm quite pleased with the purchase considering it is about 1/3 the cost of a miller, lincoln, etc.... Im going to make a welding cart for my first project and get this figured out a bit more before i start welding on bikes.
The following user(s) said Thank You: PLUMMEN, 80B4
- loudhvx
Re: Eastwood Welder TIG 200 review
03 Mar 2015 22:47
Looks great! That goes to the top of my wish list.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
04 Mar 2015 06:11
very nice sir you will have it mastered in no time :evil: !
- 80B4
04 Mar 2015 08:50
I've been looking to get a TIG machine for my shop at home and that Eastwood welder is very interesting. We ahve a Miller 250 syncrowave at the shop and it's a good welder but it is huge compaired to some of the newer welders. Please keep us updated on your new welder!
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- DoctoRot
08 Mar 2015 23:16 - 08 Mar 2015 23:5280B4 wrote: I've been looking to get a TIG machine for my shop at home and that Eastwood welder is very interesting. We ahve a Miller 250 syncrowave at the shop and it's a good welder but it is huge compaired to some of the newer welders. Please keep us updated on your new welder!
My buddy Eric, who is teaching me, has a Miller 250 Syncrowave. He does some pretty crazy chit with that. I watched him weld up a crack in a magnesium wheel the other day. I didn't even know you could weld magnesium, figured it would catch on fire. Occasionally he does jobs offsite, and he has been thinking about getting an inverter because they are much more portable, and don't require 220v to run.
Eric had me get a gas lens for the torch, along with some ceriated tungsten. I have been using 3/32 but have some 1/16 as well. The torch is a standard air-cooled so welding shops have parts on the shelf for them. no proprietary BS.
The only negative thing I read about this package before I got it was the regulator was chintsy. After a couple hours of use the regulator started whining and the needle would rattle really loud on the flow meter when I was using gas. I found this $250 Gentec flowmeter on craigslist for $50! its like brand new.
www.amazon.com/Gentec-Flowmeters-Regulat...rds=gentec+flowmeter
My only gripe, which is small, is the amp dial for the footpedal is on the footpedal, not the welder. So you have to be careful not to change the dial when moving the pedal with your feet. Other than that the setup seems great.
I have gotten confident enough with my skills that I took a break from working on the welding cart and repaired my luggage rack for my 650. it was cracked through on both sides and barely hanging on. I also added a brace to prevent this from happening in the future. One side got a bit funky because the crack was going through the original braze, I welded it up using silicon bronze filler, which was very tricky to use.
I don't know why I waited so long to get a welder, I'm loving it!
Last edit: 08 Mar 2015 23:52 by DoctoRot.
The following user(s) said Thank You: 80B4
- DoctoRot
12 Mar 2015 20:26
13 Mar 2015 06:00
yes you are good job man.
- DoctoRot
18 Mar 2015 16:06Please Log in or Create an account to join the conversation.
19 Mar 2015 05:53
saweeeet!
you'll have that from now on!
- KZQ
- Administrator
19 Mar 2015 06:13
Nicely Done!
Are you going to move on to some aluminum?
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- DoctoRot
19 Mar 2015 14:38KZCSI wrote: Nicely Done!
Bill
Yes. big part of buying this is to make a kayak trailer to haul 10 kayaks. I will be doing that in aluminum.
- NakedFun
19 Mar 2015 15:33
Very Sexy! Nice welds on that cart!
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
