  • Page:
  • 1
  • 2
emgo carb sync tool 06 Apr 2011 01:31 #442921
  • Lowz650
  • Lowz650's Avatar Topic Author
  • Thank you received: 0
Just purchased a vaccum gauge style carb sync tool made by emgo company looks fairly legit wanted to get some feedback if anyone ever used it and if it was a bum purchase or good one.
emgo carb sync tool 06 Apr 2011 08:17 #442940
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
  • Thank you received: 80
Does it look like this?
'85 GPz550(ZX550-A2)
emgo carb sync tool 06 Apr 2011 10:03 #442952
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Don't you have to calibrate those? I need a set and was looking at that specific one.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
emgo carb sync tool 06 Apr 2011 10:10 #442953
  • Thank you received: 2098
Could attach each gauge to the same carb, and compare readings among the gauges to determine equality of indicated measurements on the known identical vacuum.
Good Fortune! :)
Last edit: by Patton.
emgo carb sync tool 06 Apr 2011 10:41 #442957
  • jjack010
  • jjack010's Avatar
  • Thank you received: 3
I have the one's that are pictured. I did have to "zero" them out before first use. Also, I replaced the hose's that came with them for better quality hoses from the local auto parts store. The original ones started to split when installing on fittings.
1974 Kawasaki Z1
Central Texas
emgo carb sync tool 06 Apr 2011 12:44 #442970
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
whats involved in zeroing them
emgo carb sync tool 06 Apr 2011 12:50 #442971
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
jus1975 wrote: whats involved in zeroing them
there should be a screw or something on the back
1975 Z1 900
2004 KX125
emgo carb sync tool 06 Apr 2011 13:02 #442975
  • jus1975
  • jus1975's Avatar
Do you have to connect them to an air source first to get them in together or just turn till the needle is on zero
emgo carb sync tool 06 Apr 2011 13:52 #442986
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
  • Thank you received: 28
You can use the T's and some extra line to connect them all down to one hose. Then just use a constant source of vacuum (carb w/engine running is too bouncy) and get the needles up about 1/3rd the guage, then calibrate them and repeat a couple times to ensure accuracy.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
emgo carb sync tool 28 Apr 2011 11:31 #447537
  • alwaysbroke
  • alwaysbroke's Avatar
I've used a small shop vac to calibrate a similar tool. It wasn't specifically for a bike but it was still a manometer. I drilled a hole in the center of the cork then forced / glued a tube in it. At first it pegged the gauge so we stuffed some rags into the shop vac's air exit to help bring it down to a useable level. We also put a fan on the shop vac to help it keep from getting too hot.
Just throwing that out there.
'75 Z1900
'74 CB750
emgo carb sync tool 09 Nov 2011 01:47 #487736
  • wargoth
  • wargoth's Avatar
I own 2 sets of vintage Motion Pro Mercury Synch gauges. They are 4 very small ID plastic tubes attached to a board with graduations. They use Mercury in a small "tank" at the botom of the set of tubes. Mercury can be difficult to replace now since it is very difficult to buy in most places.
Motion pro makes one still, but it uses a blue fluid in it instead of mercury, they dont want us to hurt ourselves after all. I have no idea how the new style works, but the mercury type are extremely accurate and require zero calibration.
motionpro.com/motorcycle/partno/08-0411/
The dial type gauges must be calibrated even when the temperature changes, and that is a pain in the ass IMO.
. 09 Nov 2011 02:10 #487742
  • KZ250LTD
  • KZ250LTD's Avatar
  • Thank you received: 16
79 KZ1000ST
Past:
Many.
Last edit: by KZ250LTD.
  • Page:
  • 1
  • 2
