  • Page:
  • 1
OEM TOOLS? 11 Feb 2011 06:56 #429937
  • Grinder
  • Grinder's Avatar Topic Author
  • Summerville SC long time KZ owner Short time membe
  • Thank you received: 0
Is there a list of oem tools the came with KZ1000?
i have a tool pouch that i have put together!
8,9,10,12mm open and boxed end
spark plug socket
screw drivers
plyers
adjustable wrench
sand paper
wireing diagram
replacement fuses
OEM TOOLS? 11 Feb 2011 07:12 #429941
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 303
Yes, I believe there is, but they are not listed on the Kawasaki website diagrams. I seem to recall the owners tools being listed on the microfiche, which I have at home. If no one posts an answer to your question today, I'll look tonight at the microfiche.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
OEM TOOLS? 11 Feb 2011 10:32 #429982
  • hocbj23
  • hocbj23's Avatar
  • Visitor
I have a couple of what I believe are complete tool pouches for the KZ.Contents are as follows:24,22,19 mm box ends,17/14,13/12and 10mm open ends, black screwdriver handle with phillips and flat tip inserts,R20.5 spanner for shock adjustment,extension handle for the box ends,pliers,plug wrench with handle.Earlier models had gap gauge for plugs/points and I have one of those as well.Spare fuses are carried in the fuse box cover.hope this helps.bj
OEM TOOLS? 11 Feb 2011 10:45 #429985
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
  • Thank you received: 28
Pretty self explanetary form the image.
9 is a feeler gauge
16 is a plug wrench
18 is some gasket sealer
The whole origional kit can be purchased for around $80
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: by TeK9iNe.
OEM TOOLS? 11 Feb 2011 11:54 #429992
  • Thank you received: 2098
1973 Z1 tool kit
OEM TOOLS? 11 Feb 2011 15:43 #430038
  • gane
  • gane's Avatar
  • Thank you received: 1
This will sound retarded, But.I own an "original" tool kit, & owners manual. Neither travels w/me. I do however have a "Dick & Jane" 3 page fold 0ut wiring diagram,(which resides in the tail section w/ reg/ins.forms) & since I run "Pods" a velcro/nylon "tool pouch" which hangs from the frame rail inside the r/h side cover. It includes 8-17mm Craftman wrenches,4-8mm allen wrenches, an axle spanner & extension, a plug socket,a "stock" screwdriver handle w/straight & phillips bit, a "home made" test light, safty wire, elect tape(wound around extension) spare fuses, a set of plugs a couple 1157/1156 bulbs. a stock points plate & advance unit, a small crescent wrench, a small pair of pliers & a joint. The quality of "stock" tool kit componants were POOR at best. DO YOUR' WORK AT HOME... Yes, emergencys will arise on the road, cover the consigancys you can without back-up & ride close to home for the first couple hunnert miles. Never plan on a extended outing without a pre-ride. luck g
[img][/img] 1977 KZ1000A1
OEM TOOLS? 11 Feb 2011 19:35 #430099
  • Grinder
all real good advice. kinda the way i was leaning , was to put together something of quality from my coloction of tools and get a axel wrench, shock spanner, plug socket to carry in a leather pouch i have. and i do know this bike is 30+ year old machine. i am leaving stock airbox and dont have a lot of room.
My last bike had room for 20 lbs of stuff!
thx again
Last edit: by Grinder.
OEM TOOLS? 11 Feb 2011 19:38 #430100
Enjoy also carrying a short length of hose that fits snugly over a spark plug to remove while hot without burning fingers.
Good Fortune! :)
OEM TOOLS? 21 May 2011 02:42 #452517
  • Michelle4Edwards
  • Michelle4Edwards's Avatar
  • Visitor
gane wrote: This will sound retarded, But.I own an "original" tool kit, & owners manual. Neither travels w/me. I do however have a "Dick & Jane" 3 page fold 0ut wiring diagram,(which resides in the tail section w/ reg/ins.forms) & since I run "Pods" a velcro/nylon "tool pouch" which hangs from the frame rail inside the r/h side cover. It includes 8-17mm Craftman wrenches,4-8mm allen wrenches, an axle spanner & extension, a plug socket,a "stock" screwdriver handle w/straight & phillips bit, a "home made" test light, safty wire, elect tape(wound around extension) spare fuses, a set of plugs a couple 1157/1156 bulbs. a stock points plate & advance unit, a small crescent wrench, a small pair of pliers & a joint. The quality of "stock" tool kit componants were POOR at best. DO YOUR' WORK AT HOME... Yes, emergencys will arise on the road, cover the consigancys you can without back-up & ride close to home for the first couple hunnert miles. Never plan on a extended outing without a pre-ride. luck g
Its good variety and nice pic which is in black and white.
OEM TOOLS? 21 May 2011 09:52 #452540
  • dshelly
  • dshelly's Avatar
  • Thank you received: 5
with all this talk about tool pouches I have a question. So on the Kz1000's where was the tool kit kept on the bike? in the tail? in the tray? I know my 900 ltd has a specific tool box, but I don't see one on my 1000.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
OEM TOOLS? 21 May 2011 12:14 #452563
  • grumpy56
  • grumpy56's Avatar
  • Thank you received: 6
On the 1982 J2 it is kept under the seat next to the battery. The tail section is for "owner's papers" (as i read or saw some where).
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • Page:
  • 1
