Compressed air line in the shop 22 Aug 2010 17:27 #393067
  • tybolt99
  • tybolt99's Avatar Topic Author
  • From where KZs came
  • Thank you received: 3
Thank you all.
I ended up using PEX and fittings I had left from house.
From compressor, shut off/30" rubber hose/ quick connect/PEX line. Up to here is outside.
Run PEX line sloping down /T down to drain, up to shut off/ T off to regulator and quick connect to air hose, terminate another with shut off for now (will extend this to hose reel at ceiling in the future).
Old emglo is running fine and no leak from line but leaking from cheap HF filter/regulator/lube unit:angry: I need to mess with it some more.
I ran out of time today. I will have to wait till next weekend to do some more.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
Compressed air line in the shop 22 Aug 2010 20:01 #393112
  • Thank you received: 2098
Using teflon tape on threaded connections may help prevent leaks through the threads.
Good Fortune! :)
Compressed air line in the shop 23 Aug 2010 05:27 #393158
  • tybolt99
Good Fortune! :)
Thanks, Patton.
Went back out last night to mess with it little more.
O ring on top of the filter and lube bowls were not seating property. Put teflon tape on thread of the ring that attaches bowl and cage to the body stopped leaks.
It is this one. www.harborfreight.com/air-tools/air-acce...regulator-92261.html
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Compressed air line in the shop 23 Aug 2010 06:19 #393170
  • BSKZ650
  • BSKZ650's Avatar
  • Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
Last edit: by BSKZ650.
Compressed air line in the shop 23 Aug 2010 17:44 #393312
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
Compressed air line in the shop 23 Aug 2010 18:41 #393334
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Thank you received: 1278
The OSHA cadre have whipped up the froth to the point that even if you choose the orange PVC you still have to prove that the oil in your compressor will not attack the PVC pipe. I went down to the local hydraulic repair shop and bought a bunch of 5/8" rubber hydraulic hose with crimped connectors. I attach it to the wall with conduit clamps and have moved shops several times. I'm exempt and flexible.
For a home shop I'd go with PEX.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Compressed air line in the shop 23 Aug 2010 19:54 #393359
  • tybolt99
Bill
PEX is easy to work on. That's what I like about. So far working good.;)
Thanks, Bill.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
Compressed air line in the shop 23 Aug 2010 19:57 #393360
  • PLUMMEN
  • PLUMMEN's Avatar
pex will actually expand many times its diameter and return to origional size,just be carefull to get the right fittings and crimp them right B)
