Budget Soda Blaster 31 Aug 2009 19:39 #318083
  • 650ed's Avatar Topic Author
  • Thank you received: 2829
Compliments of "harm" and KZ250LTD:
Blaster
Before & After
The following user(s) said Thank You: kscanuck785, vwgtiguy
Budget Soda Blaster 04 Sep 2009 21:17 #319176
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
  • Thank you received: 1
How have I never seen this before?? I must have one.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Budget Soda Blaster 06 Sep 2009 12:28 #319514
  • TerryK
  • TerryK's Avatar
Holy shit, why didn't I think of this? Thanks for sharing!!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Budget Soda Blaster 10 Sep 2009 00:47 #320357
  • spearsgaryhi
  • spearsgaryhi's Avatar
  • Thank you received: 0
Kick ass, Thanks.:)
Budget Soda Blaster 27 Sep 2009 18:11 #324376
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Thanks, this should be a big help to me, JD
78 KZ1000 A2A
Budget Soda Blaster 01 Oct 2009 16:12 #324927
  • Sweet Back
  • Sweet Back's Avatar
Just wondering if this would be useful for plastic pieces like a side cover for prep to paint. Seems like it wouldn't cut into it like glass or shells might. Any thoughts?
1996 KZ1000P
Last edit: by Sweet Back.
Budget Soda Blaster 18 Oct 2009 09:52 #328226
  • ndfez
  • ndfez's Avatar
I sandblast for a living,but I use the Black Magic stuff(coal an glass mixture),I heard of this soda blasting for cars an such but never thought of it for this way.Learn something new everyday.:cheer:
Budget Soda Blaster 18 Oct 2009 11:28 #328233
  • 2DAMFAS
  • 2DAMFAS's Avatar
Hello great idea was wondering if i wanted more abrsive results if salt could be used it to will disolve in water thank you
Budget Soda Blaster 20 Oct 2009 09:40 #328577
  • YUKABODOS
  • YUKABODOS's Avatar
I do not think I would use salt on metal. Any residue will cause rusting and these bikes are already 25- 30 yeas old.
Not a great idea. Ever been to the NE where salt is used on roads. Cars have a vastly redced lifespan.
I would look for an alternative media.
Budget Soda Blaster 28 Oct 2009 10:03 #330097
  • pyxen
  • pyxen's Avatar
  • Thank you received: 7
sugar could work.. couldn't it?
84 KZ550-F2 LTD
93 ZR550-B4
Budget Soda Blaster 28 Oct 2009 14:49 #330142
  • Norseman
  • Norseman's Avatar
There is a grade of soda specifically for blasting, I believe my local TSC sells it, or at least can order it (I hope so cause I'm running out, drats). The cooking grade soda you buy in food stores are not very effective as a gentle abrasive, but does great in surface cleaning such as varnish deposits, etc. Whereas the blasting-grade soda is great for paint removal, surface prep for re-paint, etc. That grade is all soda, but much more coarse, and you can buy it in greater bulk much cheaper than food-grade soda.
Salt is definitely out-of-the-question for obvious reasons stated above. I would not use sugar since I can't ensure all of it gets disolved and washed away prior to heat. The benefit of soda is in its ability to completely disolve upon contact with moisture as it reacts instantly by expanding, foaming and then simply washing away. Easy clean-up! I use it extensively on delicate surface prep and clean-up.
Last edit: by Norseman.
Budget Soda Blaster 30 Oct 2009 20:32 #330581
  • nads.com
  • nads.com's Avatar
  • Thank you received: 20
Somebody tell me how salt can rust metal once it's been washed off? Are you guys paranoid or what? Gimme a break here.
