  • Page:
  • 1
82 440 engine info required 07 Nov 2005 18:10 #7073
  • TwoSeven
  • TwoSeven's Avatar Topic Author
  • Thank you received: 0
I'm designing some new pipes for my bike - being a student am too poor to buy new ones. While I am at it, I wouldnt mind some other infor if possible - doesnt have to be totally accurate, ballpark for some of it will do.
Peak Power (bhp - rear wheel):
At what engine rpm:
Rough idea of torque
Front sprocket teeth:
Rear sprocket teeth:
(I have non-standard on mine, so need to know orig).
Internal gear ratios:
Primary + 1st thru 5th.
(something like 2.212, 3.166 etc)
chain type and #links (eg. 425 with 110 links)
cheers.
Andy
82 440 engine info required 07 Nov 2005 19:00 #7089
  • steell
  • steell's Avatar
  • Thank you received: 208
Check out www.kz400.com and you may find what you are looking for :)
82 440 engine info required 08 Nov 2005 16:19 #7224
  • TwoSeven
cheers.
I'll use 40ps@8.5k rpm, 2.6kg-m/7krpm
have end ratios but not originals, so will try and guestimate.
  • Page:
  • 1
