  • Page:
  • 1
found a kz750 frame+ parts!!! 22 Jul 2006 22:08 #63995
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
  • Thank you received: 1
i went to the junk yard for parts for my geo tracker, and didnt find them!!
on the way out i saw a frame and was courious, it looked like my bike, i looked and it was a kz750
not sure what year it is ,ill go back and get it for parts tho.
i do remember the serial # was pretty low somthing like #000475 or so!!
i will be going back on monday and get it so ill find out more then
it did have dual front brakes and rear disc brakes.
nice gauges and hardware! may be more also!!!!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
found a kz750 frame+ parts!!! 23 Jul 2006 00:33 #64008
  • steell
  • steell's Avatar
  • Thank you received: 208
None of the 750 twins came stock with dual disk front brakes, but the dual disk kit that was available for the KZ1000 worked equally well for the 750B, so it wouldn't surprise me that a few owners installed them.
Quick guide to year of 750 twins:
76-77 have a round front master cylinder while 78-79 have the trapazoidal one.
78 has a on/off switch on the right side switch pods for the lights, 79 has a block off plate there.
80 has a black plastic rear fender instead of the chrome one on the 76-79 models. And it has the triangle shaped sidecovers instead of the long skinny ones on the 76-79, also has three mounting holes for the sidecovers instead of four.
If you find a 76-79 750 twin with mag wheels, grab it, it probably has Morris Mags on it (Dealer installed). 80 also has mags with rear drum brake.
Post edited by: steell, at: 2006/07/23 03:34
found a kz750 frame+ parts!!! 23 Jul 2006 12:57 #64063
  • apeman
  • apeman's Avatar
  • Thank you received: 3
It could be a four cylinder KZ750, as these were more common, and all of them came with dual discs up front and single disc rear. There should be something in the serial number to show it as an E, H, L, P or N model. The B models were the twins.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
found a kz750 frame+ parts!!! 24 Jul 2006 12:18 #64277
  • steveo_4192003
  • 77kz650b-1
i will grab it up!
i do belive it was a four cyc.. as described by apeman, only cause it does have the dual front set up and rear disc setup! but not to sure yet.
i will find out thursday when i get it!
(budget resricted) as we all are these days,
ill also get a pic and post it.
hopefully i can use some parts for my 77 kz650 b-1
  • Page:
  • 1
