  • Page:
  • 1
KZ 550 Valve Clearances 22 Jul 2006 17:13 #63931
  • The Gringo
  • The Gringo's Avatar Topic Author
  • ¡Usted no necesita otra motocicleta!
  • Thank you received: 11
Hi I'm hoping someone out there has a service manual and can tell me the correct valve clearances for an 81 KZ 550 engine. Thanks in advance.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
KZ 550 Valve Clearances 22 Jul 2006 19:01 #63950
  • oldcoldankles
  • oldcoldankles's Avatar
  • Thank you received: 3
On the 1983 KZ550 the manual specifies:
intake valve is .004- .008" and
exhaust valve is .006-.010".
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
KZ 550 Valve Clearances 23 Jul 2006 17:49 #64091
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1616
And, as I've mentioned before, don't bolt down the valve cover with the chain tensioner set. relaese the tensioner when bolting down the cover and re install it after the cover is on.
A manual will usually give those types of warnings that may not seem obvious, so a manual would be a good thing to get.
Post edited by: loudhvx, at: 2006/07/23 20:50
  • Page:
  • 1
