  • Page:
  • 1
Shifter problem 20 Jul 2006 20:19 #63530
  • krazy550
  • krazy550's Avatar Topic Author
  • Thank you received: 0
I just got fire in the cylinders,bonus! so now I have to solve a trans problem. The guy i got the bike from said that the clutch rod broke, they replaced it, but I knoticed that the shifter shaft is stiff , not returning , an is not sticking out of the case enough to get the shifter fully on, does this ring any bells before I start taking things apart? I hate trying to figure out other peoples work.
Thanks
1980-kz550
Shifter problem 20 Jul 2006 21:09 #63533
  • trippivot
  • trippivot's Avatar
  • Thank you received: 3
not good. proceed with caution. do not ride it until that is addresed AND SOLVED!!
Shifter problem 20 Jul 2006 22:54 #63551
  • steell
  • steell's Avatar
  • Thank you received: 208
Take a good look at the cover, chances are it's not all the way on.
Shifter problem 20 Jul 2006 23:12 #63559
  • rattler
  • rattler's Avatar
agrees.... i tap mine on with a rubber hamer.
Shifter problem 23 Jul 2006 22:29 #64158
  • krazy550
:woohoo: Lucked out with this one. the stiff shifter was a case side cover put on bass ackward, the second problem of no clutch ingaugement was some meathead had put a yamaha cable on it, I just happen to have a new cable for it an after I installed it it worked great.The scary thing was that this bike was at the local bike guy shop 'highly rated',an was deemed a problem bike that no one was able to fix.
Thanks
1980 kz550
N.S.Canada
  • Page:
  • 1
