  • Page:
  • 1
Metal half moon gaskets 18 Jul 2006 12:19 #62931
  • Wizzard
  • Wizzard's Avatar Topic Author
  • Thank you received: 0
Does anyone know where to get the metal half moon gaskets I gess there called that go in the head under the valve I have the rubber one and of corse they leek so I want to try the metal ones. I have even seen them in diferent colours but can't rember what web sit I was on. Thanks for any help.
WIZZARD B)
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
Metal half moon gaskets 18 Jul 2006 12:21 #62932
  • wireman
  • wireman's Avatar
  • Visitor
z1 ent,or ape.check links section;)
Metal half moon gaskets 18 Jul 2006 12:22 #62933
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
  • Thank you received: 59
I think APE do them. Stick them in with some Threebond.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Metal half moon gaskets 18 Jul 2006 14:20 #62956
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Thank you received: 181
For some bikes these work well, for others, they can be a nightmare.
I ran into a problem with my turbo'd Z1 - it had the billet cam-end plugs in the head and just continued to puke oil. I ended up replacing them with the stock style rubber ones and the problem went away.
After I had the problems with the billet cam-end plugs a local customer took them (against my advice) and put them in his bike - the fit perfectly and didn't leak.
What I found from digging deeper is Kawasaki didn't always do a great job of line-boring for the cams. You would expect the line-boring to be a perfect intersection between the head and the cam caps - well on some engines it's not - sometimes off by many thousanths of an inch. I went around and measured 10 or 12 heads here and was surprised to get variation between each head. The worst ones being the earlier Z1 heads.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Metal half moon gaskets 18 Jul 2006 19:13 #62997
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 239
Stay rubber and use Yamabond #4 sealer or equiv and they won't leak.
Metal half moon gaskets 18 Jul 2006 20:40 #63028
  • rattler
  • rattler's Avatar
ape dose carry them and i think jeff dose to . i have had the blue ones on my kz1000 for a couple of year now with out any problems.
ronkz650 as for the yamabond sealer that all i use thats some good sh!T.
Metal half moon gaskets 18 Jul 2006 21:31 #63046
  • EddieBoy
  • EddieBoy's Avatar
a few wraps of 1\4 inch teflon tape works for me. no leaks. works good if the rubber has shrunk a little.
Metal half moon gaskets 18 Jul 2006 21:31 #63047
  • EddieBoy
  • EddieBoy's Avatar
lol...quarter inch
Metal half moon gaskets 19 Jul 2006 10:24 #63158
  • Wizzard
Sounds better 14" is alot no wonder no leaks. Ha! Ha! :woohoo:
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
Metal half moon gaskets 19 Jul 2006 11:48 #63178
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
That's why the heads and cam caps are machined together. It's not necessary for the cam cover to be included in this process, as long as the end plugs are made of cheap compressible rubber, not expensive uncompressible ally. Mr Kawasaki san not so stupid after all... ;)
760cc - 8.69@162mph
Metal half moon gaskets 19 Jul 2006 23:53 #63293
  • APE Jay
  • APE Jay's Avatar
  • Banned
  • Thank you received: 58
Metal half moon gaskets 20 Jul 2006 05:38 #63329
  • wireman
  • wireman's Avatar
  • Visitor
APE Jay wrote:
kzzone.com/plugs.html
ya need to send that valve cover back to glassbading cabinet Jay,still got some paint on there!:P
  • Page:
  • 1
