  • Page:
  • 1
KZ 750 Twin Engines 18 Jul 2006 04:56 #62810
  • gs1100g
  • gs1100g's Avatar Topic Author
  • Thank you received: 0
Hi ppl, In relation to my rebuild occurring. Did Kawasaki make changes to the twin's engines over the 1976 - 84 years manufacture. Hopefully not, maybe to make things easier for me. LOL Tks in advance Trevor.:huh:
KZ 750 Twin Engines 18 Jul 2006 05:14 #62819
  • cnyl
  • cnyl's Avatar
  • Thank you received: 5
I think they made changes after 79-80. I think..:whistle:
Some of the other twin heads will chime in here soon. I'm still learning about my 79.:P
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
KZ 750 Twin Engines 18 Jul 2006 05:30 #62825
  • grace1
  • grace1's Avatar
hi trevor i just emailed ya
saw yur q though . ring me if you like i have the w/shop manuals if you need torques or anything i kow they changed some casings on the clutch side and some cosmetics on the ltd and the csr i think it was called
but i reckon the head etc may have been same , my
mob is 0407949671
cheers graeme
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
KZ 750 Twin Engines 18 Jul 2006 05:44 #62829
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
  • Thank you received: 7
Yes!
Here's how it goes:
'76 - '79: pretty much the same (especially the engine)
'80, '82, '83: Different than above, but not much.
Clear as mud?
:P ;)
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
KZ 750 Twin Engines 18 Jul 2006 17:50 #62980
  • cnyl
  • cnyl's Avatar
M u d :laugh:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
KZ 750 Twin Engines 18 Jul 2006 17:59 #62982
  • 77KZ650
  • 77KZ650's Avatar
come on steell, we know you know twins...
07 MDP Rookie of the Year
KZ 750 Twin Engines 18 Jul 2006 18:54 #62992
  • steell
  • steell's Avatar
  • Thank you received: 208
You think? :D
To many little difference to list, but it kinda goes like this:
76-77 had a regulator controlled alternator, so reg/rec are different as is alternator and cover. Also had 1/2" round top front master cylinder.
78-79 have permanent magnet alternator and trapozoidal shaped cap on a 5/8" master cylinder. 79 was last year of rear disk brake.
80 has different sidecovers/tail, and a 1/2" rectangular cover on the front master cylinder, no center stand, and the carbs are a little different (don't ask how I know). Mag wheels stock with rear drum brake
Engines on the above models are all pretty much the same.
81 not produced.
82 is first year for the emission head and valve cover, pull knob choke, and has emission carbs with only one clip position on the needles. Also has electronic ignition. CSR model with leading axle forks and spoke wheels.
83 is last year of production and has belt drive and a center stand, otherwise looks like an 82. Edit: 83 may have had mag wheels also, don't remember at the moment.
History in a nutshell :D
Post edited by: steell, at: 2006/07/18 21:56
KZ 750 Twin Engines 19 Jul 2006 02:25 #63099
  • gs1100g
:unsure: Gees is that all ?? LOL So I assume that the internals will probably be the same then. Tks for that Ppl Gs1100g
  • Page:
  • 1
