  • Page:
  • 1
  • 2
displacement 15 Jul 2006 21:18 #62289
  • RedneckSamurai
  • RedneckSamurai's Avatar Topic Author
  • Thank you received: 1
Is there an easy way to see if an engine has been bored or modified?
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
displacement 15 Jul 2006 21:22 #62291
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
  • Thank you received: 29
A compression check would be my first guess, although if the engine has considerable wear even that might not be a tell-tale sign of any engine mods.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
displacement 15 Jul 2006 21:28 #62295
  • RedneckSamurai
thats what I was thinking, but if its even across all four and not 8.5:1 it would suggest if has been modified?
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
displacement 15 Jul 2006 21:37 #62300
  • wireman
  • wireman's Avatar
  • Visitor
pop the carbs or header off and look inside of ports,pop valve cover off see if head has been clearanced for cams,look at front of cylinder does it say 903 or 1015............ ;)
displacement 15 Jul 2006 22:24 #62308
  • APE Jay
  • APE Jay's Avatar
  • Banned
  • Thank you received: 58
You can not tell compression ratio by doing a compression test. Compression test only measures cylinder pressure.
Compression ratio is a mathematical equation involving cylinder displacement and combustion chamber volume.
Jay
displacement 16 Jul 2006 07:30 #62339
  • RedneckSamurai
Right, but if the compression is the same across all 4 and it's higher than my stock motor, wouldn't it suggest it has been modified?
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
displacement 16 Jul 2006 08:06 #62347
  • btchalice
  • btchalice's Avatar
  • Thank you received: 7
high compression just means good rings it wont tell you the ratio
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
displacement 16 Jul 2006 09:26 #62364
  • donthekawguy
  • donthekawguy's Avatar
  • Thank you received: 8
Your stock motor could have low compression. Mine has around 110 in each cylinder so just about any bike will have higher compression than mine. :( The only real way to check is pull the head off and measure the bore.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
displacement 16 Jul 2006 11:02 #62387
  • RedneckSamurai
Well I guess there is no easy way. So I just stopped caring about it, until I have to get in there for another reason. Thanks guys.
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
displacement 16 Jul 2006 11:10 #62390
  • steell
  • steell's Avatar
  • Thank you received: 208
I picked up a GPz750 motor, and when I did a compression test it showed 180 psi on all cylinders. My first thought was "Wow! I got lucky! This thing must have an 810 kit in it!", so I pulled the head to verify it.
I discovered that it had a stock bore and carbon build up in all cylinders was causing the high readings :(
displacement 16 Jul 2006 12:40 #62403
  • nads.com
  • nads.com's Avatar
Carbon build up is common when the mixture is rich. My 900 had 224 from that. Compression does not mean more power. Once you have more comp. than than the amount of air the heads can flow your done. Ive seen this with auto as well. Anyone with a 12 or higher ratio should definetly have over sized valves. Then cams. Then ..... yeah..... riding across the country, just rained, fresh air, plenty of power, if only i had a sixth gear..... hammer that sucker and listen to it wind up, when the pitch is high and it sounds like its gonna blow, ok here we go rrrrrrrrrrrrrRRRRRRRRREEEEEEEEE,EEEEEEEEEEE,eeeeeee,thats third gear to fifth. pull in the clutch, coast for miles, wow.
displacement 16 Jul 2006 18:13 #62461
  • APE Jay
  • APE Jay's Avatar
  • Banned
Not necessarily. If a motor had aftermarket pistons with 10.25:1, but also had longer duration cams which will bleed off cylinder pressure, you might get it to only pump what a stocker does.
On the other hand, some one who is playing around with cam timing on a stock motor, and spread the overlap out, which can cause cylinder pressure to raise even though the motor is stock.
One has to really measure and examine components to see if the engine has been modified.
Jay
Post edited by: APE Jay, at: 2006/07/16 21:15
  • Page:
  • 1
  • 2
