- Thank you received: 4
Clutch brand
- Maxbou92
22 Jun 2024 12:00 #901122
by Maxbou92
Kz750e 1980
Clutch brand was created by Maxbou92
Hi everyone, does somebody know what is that clutch?! I bought it from ebay, it was supposed to be a Oem Kz750 clutch!! Don’t really sure about it … I look some others brand and they are not looking like these one!! Thank youu
Kz750e 1980
- gd4now
- Denco where did you go?
- Thank you received: 429
22 Jun 2024 12:26 #901126
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Clutch brand
I can not tell from the pic what clutch you purchased. Keep in mind that for the 1980 model year Kawasaki offered a twin 750 and a four 750. Partzilla indicates the following part numbers
for the twin (KZ750 G1 also called LTD II) 13081-1006
for the four (KZ750 E1) 13081-1034
I do not know if there are differences between the 2 parts, but would assume there are as they have different part#s and Partzilla indicates the twin clutch was used only on the 750 twins. While the clutch on the four was used on several different 750 four models/years and some 650 H models as well.
Maybe what you purchased is OEM but intended for the twin(s)
1977 KZ650 B1
- Thank you received: 2053
22 Jun 2024 12:52 - 22 Jun 2024 13:02 #901131
by Scirocco
Replied by Scirocco on topic Clutch brand
You just can only give it a try. If the clutch parts fit into the inner/outer clutch hub/basket, have the right thickness and stack high, you are fine.
Last edit: 22 Jun 2024 13:02 by Scirocco.
- Maxbou92
22 Jun 2024 14:01 #901142
by Maxbou92
Kz750e 1980
Replied by Maxbou92 on topic Clutch brand
Yess I have check the Plate number on Partzilla!! They are the same from kz650 to 1000 !! The Oem looks like small square on the plate friction!! Thats why Im not sure my clutch is an OEM!! The plate has a 3.7mm thickness
Kz750e 1980
- Thank you received: 2806
22 Jun 2024 14:24 #901144
by Nessism
Replied by Nessism on topic Clutch brand
The plates in the photo are not OEM plates for the 650/750 four cylinder bikes. That is not to say that they are bad per se, though.
The following user(s) said Thank You: Maxbou92
- asphalt900
- Thank you received: 271
23 Jun 2024 02:30 #901159
by asphalt900
Replied by asphalt900 on topic Clutch brand
That color and basket tabs look suspiciously Barnett.
- Thank you received: 2280
23 Jun 2024 02:37 #901160
by Wookie58
Replied by Wookie58 on topic Clutch brand
I'm with Scirocco on this, you own them now so "fire them in there" and "suck it and see"
it's not the biggest job in the world and the worst that can happen is it doesn't work correctly
- asphalt900
23 Jun 2024 03:22 #901161
by asphalt900
Exactly Wookie! Never was a huge fan of the ole vintage Barnett though. While worked as advertised, those "metal" outer basket tabs were hard on the basket slots. Had a tendency to "notch" the baskets more aggressively then OEM. Had several NOS sets years ago and sold them all.
- Maxbou92
23 Jun 2024 09:27 #901181
by Maxbou92
Kz750e 1980
Thank you guys!! Barnett disc doesn’t looks like mine at all!! I ordered OEM from Ebay (real one this time) a big deal.. 7 frictions plates for 60$ canadian !! It will be my spre clutch if the other one is bad!!
Kz750e 1980
