Clutch brand
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Clutch brand
22 Jun 2024 12:00
#901122
Hi everyone, does somebody know what is that clutch?! I bought it from ebay, it was supposed to be a Oem Kz750 clutch!! Don’t really sure about it … I look some others brand and they are not looking like these one!! Thank youu
Kz750e 1980
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Clutch brand
22 Jun 2024 12:26
#901126
I can not tell from the pic what clutch you purchased. Keep in mind that for the 1980 model year Kawasaki offered a twin 750 and a four 750. Partzilla indicates the following part numbers
for the twin  (KZ750 G1 also called LTD II) 13081-1006
for the four (KZ750 E1) 13081-1034
I do not know if there are differences between the 2 parts, but would assume there are as they have different part#s and Partzilla indicates the twin clutch was used only on the 750 twins. While the clutch on the four was used on several different 750 four models/years and some 650 H models as well.
Maybe what you purchased is OEM but intended for the twin(s)
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Clutch brand
22 Jun 2024 12:52 - 22 Jun 2024 13:02
#901131
You just can only give it a try. If the clutch parts fit into the inner/outer clutch hub/basket, have the right thickness and stack high, you are fine.
Last edit: 22 Jun 2024 13:02 by Scirocco.
  • Maxbou92
Re: Clutch brand
22 Jun 2024 14:01
#901142
Yess I have check the Plate number on Partzilla!! They are the same from kz650 to 1000 !! The Oem looks like small square on the plate friction!! Thats why Im not sure my clutch is an OEM!! The plate has a 3.7mm thickness
Kz750e 1980
  • Nessism
  • Nessism's Avatar
Re: Clutch brand
22 Jun 2024 14:24
#901144
The plates in the photo are not OEM plates for the 650/750 four cylinder bikes.  That is not to say that they are bad per se, though.
The following user(s) said Thank You: Maxbou92
  • asphalt900
  • asphalt900's Avatar
Re: Clutch brand
23 Jun 2024 02:30
#901159
That color and basket tabs look suspiciously Barnett.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Clutch brand
23 Jun 2024 02:37
#901160
I'm with Scirocco on this, you own them now so "fire them in there" and "suck it and see"  it's not the biggest job in the world and the worst that can happen is it doesn't work correctly
  • asphalt900
Re: Clutch brand
23 Jun 2024 03:22
#901161
Exactly Wookie! Never was a huge fan of the ole vintage Barnett though. While worked as advertised, those "metal" outer basket tabs were hard on the basket slots. Had a tendency to "notch" the baskets more aggressively then OEM. Had several NOS sets years ago and sold them all.
  • Maxbou92
Re: Clutch brand
23 Jun 2024 09:27
#901181
Thank you guys!! Barnett disc doesn’t looks like mine at all!!  I ordered OEM from Ebay (real one this time) a big deal.. 7 frictions plates for 60$ canadian !! It will be my spre clutch if the other one is bad!!
Kz750e 1980
