Exhaust Collars
- ErikN
21 Jun 2024 04:52 #901065
by ErikN
1983 GPz1100
1983 GPz1100
1984 GPz1100 (parked in Stockholm)
Exhaust Collars was created by ErikN
Hi All,
have a few (3 to be exact) 1983 & 1984 GPz1100 bikes. I’m having a hard time finding the exhaust collars. Part number 92027-1447. The last couple of orders I have received have both been too shallow and won’t push the header all the way in.
Is there a good source (other than random ebay sellers) for these parts or a good workaround?
Erik
Erik
1983 GPz1100
1983 GPz1100
- Thank you received: 2280
21 Jun 2024 06:33 #901067
by Wookie58
Replied by Wookie58 on topic Exhaust Collars
- ErikN
21 Jun 2024 09:05 #901072
by ErikN
1983 GPz1100
1983 GPz1100
Replied by ErikN on topic Exhaust Collars
Thanks for the correction! I had a typo in my original post.
The part number I am looking for is: 92027-1457. Seems to be unavailable at all of the online part places. I’ve bought a couple from ebay, but keep getting the wrong part. Did Kawasaki use the same part number on different parts?
1983 GPz1100
1983 GPz1100
- gd4now
- Denco where did you go?
- Thank you received: 429
21 Jun 2024 10:18 #901074
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Exhaust Collars
How much too short are they? Though have not done so I would think the fact they are split would allow them to work on many different exhaust systems. Unless there is something special about the 1100 system. You just need them to be long enough to push up tight. I would think one could make some out of pipe cut to length and then split.
1977 KZ650 B1
- Thank you received: 1918
21 Jun 2024 10:57 #901076
by Mikaw
Replied by Mikaw on topic Exhaust Collars
I have 76-78 Kz collars I can measure for you to see if they will fit. I’ll work on that later this afternoon for you
21 Jun 2024 12:58 #901078
by Wookie58
No, they may use the same part number on different models (see list in my post) but it will be the same part used across the rangeThanks for the correction! I had a typo in my original post.
21 Jun 2024 13:00 #901079
by Wookie58
If you know anybody with access to a lathe you could bet some knocked out (I made mine from thick walled alloy tube then cut them in half)
