- Thank you received: 4
Clutch thickness
- Maxbou92
17 Jun 2024 10:10 #900876
by Maxbou92
Kz750e 1980
Clutch thickness was created by Maxbou92
Hello guys, does someone has the thickness of a friction disc of a kz750 4cylinders?! Mine have 3.7mm ..
Kz750e 1980
- F64
- 81-KZ440D2
- Thank you received: 394
17 Jun 2024 10:42 - 17 Jun 2024 10:45 #900883
by F64
81-KZ440-D2.
LIC, NY
Replied by F64 on topic Clutch thickness
81-KZ440-D2.
LIC, NY
Last edit: 17 Jun 2024 10:45 by F64.
- Maxbou92
17 Jun 2024 18:36 #900907
by Maxbou92
Kz750e 1980
Replied by Maxbou92 on topic Clutch thickness
Thank youuu!! Do you know how much mm when its brand neww ?!
Kz750e 1980
- F64
- 81-KZ440D2
17 Jun 2024 19:31 #900908
by F64
81-KZ440-D2.
LIC, NY
It varies depending on brand. It could be anywhere from 3.55-3.85mm
81-KZ440-D2.
LIC, NY
- Maxbou92
18 Jun 2024 06:10 #900922
by Maxbou92
Kz750e 1980
I appreciate!! The bike has 75 000km with original clutch!! All is new, except the clutch and I’m very surprised about the « wear » of this one !!
Kz750e 1980
- Thank you received: 2806
18 Jun 2024 06:51 #900923
by Nessism
Replied by Nessism on topic Clutch thickness
Be sure to replace the springs. Stock work fine. Aftermarket springs tend to be higher tension, which can tire out your hand. Also, lube or replace the cable with OEM. You will be amazed how smooth the clutch feels with a new and lubed cable.
- Maxbou92
18 Jun 2024 07:47 #900926
by Maxbou92
Kz750e 1980
Yess thank you, I run Barnett springs and new cable!! Today I go to the Dyno!! With my new vm28ss and air jet corrector from Zed !!!
Kz750e 1980
- Injected
- Thank you received: 523
19 Jun 2024 09:09 #900969
by Injected
Replied by Injected on topic Clutch thickness
You should post the dyno results. I am thinking around 70HP at the wheel.
- Maxbou92
19 Jun 2024 13:44 - 19 Jun 2024 13:45 #900986
by Maxbou92
Kz750e 1980
I guess I will be more satisfied about it!! He was running good but not performing like I want for a new engine-porting-milled head- Vm28mm- 4-1 pipe and pods!! 155psi on each cylinders!! My girlfriend has a Fz07 and she smokes me like I had a scooter !!! ??? How many 70hp it gives to engine ?! And torque should be how many?
Kz750e 1980
Last edit: 19 Jun 2024 13:45 by Maxbou92.
