- Thank you received: 1
Oil pan bolt pattern
- Kawasakikid
10 Jun 2024 14:05 #900572
by Kawasakikid
Oil pan bolt pattern was created by Kawasakikid
There are two sizes of bolts on the oil pan. Where do the longer ones go? Shop manual only shows a few bolts and location diagram is sketchy. Thanks for help.
- Thank you received: 2806
10 Jun 2024 14:16 #900573
by Nessism
Replied by Nessism on topic Oil pan bolt pattern
Each screw should stick out above the surface roughly the same amount before threading them in. Hopefully, the engine is on the bench, and upside down. Juggle the screws into the various holes, making sure they are all equal, then snug them down.
