Oil pan bolt pattern
  • Kawasakikid
  • Kawasakikid's Avatar Topic Author
10 Jun 2024 14:05
#900572
There are two sizes of bolts on the oil pan. Where do the longer ones go? Shop manual only shows a few bolts and location diagram is sketchy.  Thanks for help.
  • Nessism
  • Nessism's Avatar
Re: Oil pan bolt pattern
10 Jun 2024 14:16
#900573
Each screw should stick out above the surface roughly the same amount before threading them in.  Hopefully, the engine is on the bench, and upside down.  Juggle the screws into the various holes, making sure they are all equal, then snug them down.
