Solenoid clicking but not turning over what am I doing wrong I'm new to this?
- Buschpush
- Forgive me if I sound dumb, new to this
06 Jun 2024 13:33 #900377
by Buschpush
Replied by Buschpush on topic Solenoid clicking but not turning over what am I doing wrong I'm new to this?
Checking the battery under load now! Will update
- Thank you received: 2281
06 Jun 2024 13:55 - 06 Jun 2024 14:02 #900378
by Wookie58
Just out of interest how much oil did you put in there ?
Replied by Wookie58 on topic Solenoid clicking but not turning over what am I doing wrong I'm new to this?
Take the spark plug out and spin the motor on the starter (once working) this will blow out the excess (will be messy) then re-fit the plug, if you are lucky there is no lasting damage. - will be smokey for a whileI lubed the cam when installing but I also lubed the piston when installing did I already fuck up big time? I am indeed new to this and completely obvious, iv built tons of go karts but never worked on a engine this big so I have a basic understanding. Pardon me for my negligence.
Am I to take it apart and empty the oil from the piston, damn I fucked up eh
I just read up on what I did, fucking hell man
Where do I go from here? Take out the engine and get out as much as I can?
Last edit: 06 Jun 2024 14:02 by Wookie58.
- Buschpush
06 Jun 2024 14:08 #900379
by Buschpush
I put it on the walls before installing the piston and before I put the top half on there wasn't any oil on top of the piston, I'm a bit confused on weather I fucked up bad or not but I put about 3/4 teaspoons and it went into the crankcase I think.
Once again sorry if I sound stupid
06 Jun 2024 15:32 #900382
by Wookie58
If you only oiled the cylinder wall and not on top of the piston you are fine (this was the right thing to do) worth checking the oil level isn't overfilled. Can you turn the engine manually with the spark plug removed ?I put it on the walls before installing the piston and before I put the top half on there wasn't any oil on top of the piston, I'm a bit confused on weather I fucked up bad or not but I put about 3/4 teaspoons and it went into the crankcase I think.
- Buschpush
06 Jun 2024 16:10 - 06 Jun 2024 17:16 #900384
by Buschpush
I can turn it manually! But great
Update; it was indeed the battery but now my compression test is saying 90psi
I just replaced head gaskets, left, right, cam and a bunch more gaskets where am I losing that much pressure?
Last edit: 06 Jun 2024 17:16 by Buschpush. Reason: Update
- Buschpush
06 Jun 2024 20:15 #900394
by Buschpush
The battery voltage is around 8-9V when I push it down!
- Thank you received: 2053
06 Jun 2024 21:43 #900399
by Scirocco
Replied by Scirocco on topic Solenoid clicking but not turning over what am I doing wrong I'm new to this?
Do the compression test again with carburator in full throttle position.
- Buschpush
06 Jun 2024 22:38 #900402
by Buschpush
It reads 100psi with throttle fully open? Normal after a gasket replacement and it hasn't run in 4 years or is it low? Where or how could I check where is using pressure? I just replaced almost every gasket
07 Jun 2024 00:12 #900406
by Wookie58
See my response to one of your other treads ref this problemIt reads 100psi with throttle fully open? Normal after a gasket replacement and it hasn't run in 4 years or is it low? Where or how could I check where is using pressure? I just replaced almost every gasket
The following user(s) said Thank You: Buschpush
