Solenoid clicking but not turning over what am I doing wrong I'm new to this?
  • Buschpush
  • Buschpush's Avatar Topic Author
  • Forgive me if I sound dumb, new to this
Re: Solenoid clicking but not turning over what am I doing wrong I'm new to this?
06 Jun 2024 13:33
#900377
Checking the battery under load now! Will update
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Jun 2024 13:55 - 06 Jun 2024 14:02
#900378
I lubed the cam when installing but I also lubed the piston when installing did I already fuck up big time? I am indeed new to this and completely obvious, iv built tons of go karts but never worked on a engine this big so I have a basic understanding. Pardon me for my negligence.
Am I to take it apart and empty the oil from the piston, damn I fucked up eh
I just read up on what I did, fucking hell man
Where do I go from here? Take out the engine and get out as much as I can?
Take the spark plug out and spin the motor on the starter (once working) this will blow out the excess (will be messy) then re-fit the plug, if you are lucky there is no lasting damage. - will be smokey for a while
Just out of interest how much oil did you put in there ?
Last edit: 06 Jun 2024 14:02 by Wookie58.
  • Buschpush
06 Jun 2024 14:08
#900379
I put it on the walls before installing the piston and before I put the top half on there wasn't any oil on top of the piston, I'm a bit confused on weather I fucked up bad or not but I put about 3/4 teaspoons and it went into the crankcase I think.
Once again sorry if I sound stupid
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Jun 2024 15:32
#900382
If you only oiled the cylinder wall and not on top of the piston you are fine (this was the right thing to do) worth checking the oil level isn't overfilled. Can you turn the engine manually with the spark plug removed ?
  • Buschpush
06 Jun 2024 16:10 - 06 Jun 2024 17:16
#900384
I can turn it manually! But great
Update; it was indeed the battery but now my compression test is saying 90psi
I just replaced head gaskets, left, right, cam and a bunch more gaskets where am I losing that much pressure?
Last edit: 06 Jun 2024 17:16 by Buschpush. Reason: Update
  • Buschpush
06 Jun 2024 20:15
#900394
The battery voltage is around 8-9V when I push it down!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
06 Jun 2024 21:43
#900399
Do the compression test again with carburator in full throttle position.
  • Buschpush
06 Jun 2024 22:38
#900402
It reads 100psi with throttle fully open? Normal after a gasket replacement and it hasn't run in 4 years or is it low? Where or how could I check where is using pressure? I just replaced almost every gasket
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Jun 2024 00:12
#900406
See my response to one of your other treads ref this problem
The following user(s) said Thank You: Buschpush
