- Thank you received: 1
Scratches on cam lobes after ~30 km ride
- KZ 1100
NoCould the camshaft have been turned while there was no valve shim in the follower?
- slmjim+Z1BEBE
- Thank you received: 732
Looks mighty dry in there. We'd expect to see oil pooled in the low area below the bucket. Oiling issue? What do the cam bearings & shims on the damaged lobe side of the head look like?Hello everyone! Recently did a head rebuild on my '82 KZ1100. Went on a first ride and after it a few of cam lobes are a bit scratched. Definitely weren't any scratches you can feel with fingernail like those before. Found this accidentally,had to change one shim for a bit smaller one.
Anyone had similar situation?
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
- F64
- 81-KZ440D2
- Thank you received: 394
81-KZ440-D2.
LIC, NY
- KZ 1100
I didn't take off cams since it's been just about 30 km since I put it together. Managed to change one shim with cam on its place.
What can be wrong with oiling? Would checking oil pressure do any good?
Oil lamp turns off when the bike start running.
The new head gasket is 2 piece just like the old one and I changed all 4 o-rings for oil passage around the studs as well.
- slmjim+Z1BEBE
Both scratched lobes appear to be on the exhaust cam at #3 and #4. That end of the exhaust cam shares a common oil supply from the right front corner stud feeding the exhaust cam bearings between #3 and #4 (cam cap #2 in the photo). From there cam lobes are lubed by splash, or, more accurately, drooling out the ends of the cam bearings. That there's no oil pooled below the #4 exhaust cam bucket looks suspicious. Can't see that area of #3 in the pics.
Is oil pooled in the low area of the head below other cam buckets?
EDIT: Hot oil pressure on an air-cooled 4 cyl. Z-bike motor is only around 3 ~ 5 PSI, lower at idle. The only plain bearings are the cam bearings which are so lightly loaded that the presence of any oil film at all is mostly sufficient lubrication, and are responsible for most of the pressure that can be read by a gauge that does develop. The remainder of the bearings in the motor are ball & roller. They depend on volume rather than pressure to live. Oil pressure gauges that can accurately read in the low-to-mid single digits are uncommon.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- KZ 1100
Just a hunch. But, cannot discount the observations of others about debris from grinding the head of the socket bolt either.
Good Ridin'
slmjim & Z1BEBE
Only the first cylinder bucket is full of oil. Other have just a drop or few. Although lobes feel like greased with oil, not like they were totally dry. On the photo you can see traces of oil on cam cap as well...
What could be wrong with oiling?
- Moose1800
- Thank you received: 296
After reading your post above it seems your not getting enough oil on the top end at all, there should be much more than a drop or two sounds like the screen is blocked with debris,
I had a cam cover plug pop out on a test ride and my leg was covered in hot oil in seconds.
- Injected
- Thank you received: 523
Its also no big deal to run the engine with the cam cover off, it just gets messy once the oil splashes around. This is a good way to make sure oil is getting to the cam lobes. Once the engine heats up on a longer ride the smoking will stop.
- Rolf1976_KZ900
- Thank you received: 159
I can se the cover laying on the floor in one pick it is easy to drop something in there not saying you did but its a possibility.
About the aperance of not oil in the lifter space that is not uncommon when bike has standing on sidestand
for five days and it is cylinder 4 the oil drains down.I can see oil in the bearing space under the camcap so it is lubed .Do you use synthetic oil?
- KZ 1100
In the bike I have fully synthetic 10w-40 Fuchs silkolene pro4.
- zed1015
- Thank you received: 1548
The roller crank hammers fully synth oils.
The only fully synth i will use in these is Rock oil TRM20/60 which is formulated with long chain molecules specifically for use with roller cranks.
As for the cam lobes.
What kind of lube did you use on the cam shells.
Excessive use of assembly paste can actually plug the oil holes in the shells and restrict the oil path to the cam and followers until the paste is flushed out after a few miles so that may the cause of the scoring.
With no oil supply at all your cams would likely be destroyed within 30 miles so you either have a restricted supply or they experienced a dry start which cleared after a short while..
- KZ 1100
You mean bearings? I just lubed it with engine oil that's all. No special stuff used.
What do you think about 4th cap?
