Where do I use high heat gasket maker apose to normal?
- Buschpush
- Forgive me if I sound dumb, new to this
02 Jun 2024 15:19 #900122
by Buschpush
Where do I use high heat gasket maker apose to normal? was created by Buschpush
So I have a 1980/81 (not sure) kz250 LTD I have to ripped apart with new gaskets ready to do on but I'm planning on using a tiny thin layer of gasket maker as well as the new gaskets to make a better seal as the last owner messed with it and I see some tiny razor marks.
My question is what and where do I use high heat apose to normal?
I know on the hear gaskets to use high heat but what around the left side (alternator) or the right side (oil filters and such)
Thanks so much
Thanks so much
- Thank you received: 2053
02 Jun 2024 20:18 #900129
by Scirocco
Replied by Scirocco on topic Where do I use high heat gasket maker apose to normal?
It´s not nessesary to use any kind of gasket maker on new gaskets.
Only if you are in the situation you have to use the old/used gasket again.
The following user(s) said Thank You: Buschpush
- sf4t7
- Thank you received: 343
02 Jun 2024 20:49 #900130
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replied by sf4t7 on topic Where do I use high heat gasket maker apose to normal?
If you are going to use the gasket maker, use the high heat one, it will work in either situation . No reason to have 2 different partial tubes on the shelf.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- Thank you received: 2216
03 Jun 2024 06:25 #900150
by TexasKZ
Replied by TexasKZ on topic Where do I use high heat gasket maker apose to normal?
Some pictures of the damage may be helpful.
