Where do I use high heat gasket maker apose to normal?
  • Buschpush
  • Buschpush's Avatar Topic Author
  • Forgive me if I sound dumb, new to this
02 Jun 2024 15:19
#900122
So I have a 1980/81 (not sure) kz250 LTD I have to ripped apart with new gaskets ready to do on but I'm planning on using a tiny thin layer of gasket maker as well as the new gaskets to make a better seal as the last owner messed with it and I see some tiny razor marks.
My question is what and where do I use high heat apose to normal?
I know on the hear gaskets to use high heat but what around the left side (alternator) or the right side (oil filters and such)
Thanks so much
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Where do I use high heat gasket maker apose to normal?
02 Jun 2024 20:18
#900129
It´s not nessesary to use any kind of gasket maker on new gaskets.
Only if you are in the situation you have to use the old/used gasket again.
The following user(s) said Thank You: Buschpush
  • sf4t7
  • sf4t7's Avatar
02 Jun 2024 20:49
#900130
If you are going to use the gasket maker, use the high heat one, it will work in either situation .  No reason to have 2 different partial tubes on the shelf.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • TexasKZ
  • TexasKZ's Avatar
03 Jun 2024 06:25
#900150
Some pictures of the damage may be helpful.
